Indivision AGA MkII Install
  • Replies Replies 128
  • Views Views 43561
Hi fitzsteve
Yeah, and I have same issue with the HDMI of the living room 46" LCD... I was about to be very disapointed when I decided to test on my small NEC multisync LCD 1550M that I just bought in USA, and I must admit the picture I get is very very neat. :roll:
... Of course Indy AGA is connected with original DVI connector + VGA adapter, not with keeper2k HDMI adapter. :(
Problem is how frustrating not to be able yet to have the neat installation that I want on a modern little LCD TV (bought on purpose!), with A600+IndiECS on VGA input and A1200+IndiAGAmk2 on HDMI input. :banghead:
Of course both should also be perfectly working in 256 colours thanks to the latests drivers and monitors... :p
Here is the A600 with IndiECS in 256 colours on the same monitor :
Did you note : 2 Mo chip ram free... while less than 1.2 Mo on the A1200 with SuperPlus 256 colours ! Well, I know : 256 colours is just for the fun... :whistle:
Conclusion : like a lot of people, I'll have to wait for the new core + configuration software... and hope ! :coffee:
But so far I have a great waiting solution with both the A600 and the A1200 connected with a VGA switch on the NEC. Only drawback is I have to launch an automatic centring adjustment but it's quick... Not too bad in the end. :thumbsup:
Glad to see you made some progress :thumbsup:
Indeed we need to wait for the new Core & Tool :)
No I have better idea : I will execute the automatic centring option of the NEC monitor when the A1200 is connected, and because this resolution will be the same (800x600) for the A600, I can play with the Indivision ECS config tool to move the screen and save the settings... Fingers crossed it will work.
I cannot get this sodding thing to work!
Ive put the High GFX driver into devs/monitor and when I click on its icon nothing happens. The HD720 does nothing either. Only the test picture work?
Probably you have the new core, does it support these modes off hand? I don't think so you might need to use the config tool to create your modes.
I don't have any experience with the tool sadly.
Hello. Took awhile to get back to this one...
Ive finally for the res up to 1024 x 768 on my widescreen Samsung HDTV.
Looks great now and going online is much better.
The mode I'm using is called CXGHIGHGFX: Super-High Res. interlaced.
The indivision AGA MK2 preferences V1.1 Tool doesn't seem to do anything. Whenever I pick a setting either on amiga mode or vga mode I press apply and it does nothing. I then get a message saying "Can't open screen. Is this monitor driver installed?"
This software if not very intuitive either. It even confused the guy I spoke to at Amigakit.
Does anyone know how to use this tool?
My monitors specs:
http://www.samsung.com/sg/support/model/LS22CRASB/XSS-techspecs
