Howdy folks
Time to share another project update with you! (Makes a change from the sales threads lol)
I got my ACA620 back today with the memory fix from Amigakit and also my A600 back from mjnurney re-capped so done the re-build today.
First of all, big thanks to MJ for the work, the board looks perfect and runs like a dream, crisp clean sound and picture
Here's the A600 with the ACA620 installed, it's also got an A604, Indivision ECS and I'm using Kippers first CF adapter which give access to the CF card by filing a slot above the PCMCIA slot.
I've got a 1.3/3.1 Rom switch which uses a toggle switch. Annoyingly the disable jumper is on the opposite side to my old ACA630 so I'm going to need to rewire the jumper cable as I did have it set to disable the ACA on selecting 1.3 Rom (for old floppy based games)
MJ also desoldered the RF unit so I can mount the VGA adapter from the Indivision at the back, I used a round file to make space for the hex nuts, the VGA adapter is mounted to the RF shield.
Here she is with 1.3Rom selected
And booting Classic Workbench Full in 800x600 (SuperPlus) from the Indivision ECS (mfilos gets the credit for the workbench setup since I stole it from him
And the SysInfo shot's as it'd be rude not to!
3.47Mips and 1.7mb/sec from the IDE, not bad for an A600!!!
And best of all the fix to the ACA620 seems to have solved the crashing issues and I'm sure the re-cap will help with overall stability too
That's all for now
That's all for now
