Hi guys, i'm having some trouble installing workbench on my A600HD.
Originally it has a 20 or 40Mb HD which boots no problem to workbench. At some point I had replaced the 2.05 ROM to a 3.1 ROM and replaced the HD to a 176MB from an A1200 and installed WB 3.1.
Anyway, some time ago I removed the 3.1 ROM to install it in my A2000 and put back the 2.05 37.300 ROM.
Now the HD refuses to boot and when switched on only goes to the INSERT DISK purple screen. The HD works because i booted up using a WB 2.04 Install disk and ran HDtoolbox which found the HD and once i quit it shows the 2 partitions.
My problem is that it won't boot and only shows the purple insert disk screen. I tried to use the 2.04 install disk to prep & install WB 2.04 or 2.05 but it won't work because its an A3000 Install disk.
I only have copies of 2.05 disks but not the install disk and I have original copies of 2.04 but again no install disk other than the 2.04 A3000 install disk.
How can I get round this to install 2.05 and get my A600 booting up to WB from HD again ?
