For Sale New Atari ST/E hard disk interface - Faster and more SD card compatible than SatanDisk
  • Thread starter Thread starter masteries
  • Replies Replies 339
  • Views Views 41068
is there a firmware update since Oct 2021 ?
Greetings Kinchan,
There is a new firmware, but only useful if your hard disk unit uses a tiny SD card holder;
previous units come with a SD card holder with a buffer chip, this chip prevents higher SD card clock usage.
While new SD card holder allows faster data transactions.
Hello Masteries, I will order 1 unit+SD.. to be used on an STE & MegaST.
(your last PM was received... I sent a new PM today)
Tested today, and it works perfectly... if it can remain functional through the years it is one of the best Atari upgrades I can think of
madalex34 , Yeroon
Your hard disk units have been sent,
You have a PM with tracking number and how to information,
Is there a way to retro fit this?
Yes, it can be installed in any of the units; for both Revision A or B
Revision A are the ones with larger SD card holder, surely your unit is Rev. A
Simply, as the image of 17 May shows (at first post), a common USB cable with one of the
end sides removed is being soldered to 5V and any GND pinout of the blue board.
There are four wires inside an USB cable, two for power, and two for data.
The two remaining wires of the USB cable, the data ones, are being ignored.
In order to secure the new power cable, a plastic flange is being used
to firmly attach the power wire to one of the DB25 case holes.
Interested in one unit please. (Hungary.) Thanks.
Your unit has been sent,
You have a message with tracking number and how to information,
Thanks!
  1. Trafo
  2. Asterios
  3. Lwjghg
  4. fratzengeballer
  5. Niezgodka
  6. Jameson
  7. Scorpiovet
  8. StrongARM
  9. BuzzBrain
  10. Flash951
  11. Mully
  12. HomeLate
  13. Winniez
  14. russellnash
  15. theGoat
  16. Lechuck
  17. Amiga Forever
  18. tkalatzis
  19. cherkasy
  20. CStich
  21. sei.lethargy
  22. Berk104
  23. macfan
  24. cloverskull
  25. smils33
  26. jurtax
  27. G-linx
  28. spatuluk
  29. MikeUK
  30. Aormelodicrock
  31. Wirerob
  32. Undertaker
  33. cyberknight
  34. SimonJ5
  35. Kitman
  36. butjer1010
  37. crrn
