Hi All,
Just thought i'd let you know i have started a new project. For those people that own an A600 you know what a pain it is sometimes to use a device that has wings on the 9 pin connector that you cannot plug into the A600 without an extension cable. Well, i have a small adapter board that will plug into both mouse and joystick port and allow all your fatter 9 pin devices to plug in with no bother.
Now the fun part, The board has a built in PS2 adapter that you can plug your ps2 mouse in. The control chip will be socketed to allow everyone to program their own code should they wish. (programmer obviously required)
Also with thanks to Paul Willingham, the board will also have a built in Playstation controller adapter so you can use your playstation controller on your Amiga or Atari. This adapter can basically be used on ANY of the old retro gaming consoles. Check out the compatibility of the psx adapter, very impressive
Here is some info on the capabilities of his adapter at work
www.kipper2k.com/PSX-Adapter.pdf
The board will also plug in directly to the ports of the A1200 with a small extender board (~$7) or a pair of extension cables. I don't have an Atari so i do not know measurements so unless i get more info the Atari's would require a pair of short extension cables..
If there is demand i may make an extender board for the A500 but my adapter will also work fine on the A500 (and the remaining models including cd32) with extension cables.
Projected cost will be ~$34 Cad and the PSX adapter cable approx ~$7 (or if you want, you can chop off the connector on your playstation controller and put on a 9 pin connector (but i dont recommend mutilating it.
Let me know if you are interested or have any questions
Release date will be ~end May, i should have some pictures at end of month, size is approx 3.5" x 1.5"
