For Sale A500 IDE adapters, PS/2 mouse adapter, A600 CF adapter
  • Thread starter Thread starter mkl
  • Replies Replies 914
  • Views Views 238209
v425
Interest temporarily withdrawn - awaiting right angle IDE only version so IDE connector can clear my VXL board.
A few versions (I have like 5 pcs prototybe pcbs each)
V426-RI : Right angle pin header on the underside, so it would possible to stick a memory card adapter through the side slot of A500.
V427: male 44 pin (2.0mm) header (on top)
V430 : female 44 pin (2.0mm) socket (on top)
V428: Right angle 40 pin header - or 40 pin header soldered to card's edge (therefore right-angle)
v429: Wide pads for 40 pin header - should be possible to use SMT pin headers, straight or right-angle (proto pcb text "426a")
I'll probably change the picture to better one(s) - this shows boards 427-430 from the underside.
and V1.22 (122): this has ide connector on other side - might make possible to use without /OVR connection. Maybe also 14 MHz "turbo" for CPU. 5volt xc9572 only.
Interested in soldered combination v425 ide+ 8MB (low profile for a500, cdtv, others) cpu plugged in 85€ - 1 pcs with "walled" connector. Looking to use on my Amiga 500 Rev6a board. ;-)
Interested in Soldered combination v425 ide+ 8MB (low profile for a500, cdtv, others) cpu plugged in - 1 piece with right angle walled connector.
interested in 1 "Soldered combination v425 ide+ 8MB (low profile for a500, cdtv, others) cpu plugged in 85€, no cpu -3€:" or "V427: male 44 pin (2.0mm) header (on top)" variant
PM coming
Hi. I have parts for a few ram68k, and some older boards to "refurbish" (such as to add epoxy glue to hold pin in place)
one unit 44pin, 68010, ram
PM coming
PM exchanged and 1 item paid,
OK for me for "one unit 44pin, 68010, ram"
Thx
2 pcs v67 rams, 2 v68 with epoxy fixes.
42€ /pce + 3€ for optional CPU (68hc000p10, 68000p12, 68010p10)
Shipping around 3€ (around 20€ with shipping code)
25 pcs lot of V425i IDE PCBS 50€ untracked shipping,
50 pcs 100€ tracked shipping.
