For Sale A500 IDE adapters, PS/2 mouse adapter, A600 CF adapter
  • Thread starter Thread starter mkl
  • Replies Replies 914
  • Views Views 238211
Should have done it the first time, but I would like the IDE board, no CPU and a compact flash adapter.
Hello, i know its an old tread but is there any of these amiga 500 ide adaptors.
i really could use on.
regards Kenneth
Interested in the A1000 8MB.
Can it be deactivated via a switch?
If any of the: Soldered combination (for a500, cdtv, others) 8MB+ide+cpu plugged 85€, no cpu -3€) are left.
Then I declare interest in one piece without CPU, as I have one already.
EDIT:
PM sent.
This is a long thread, so I have a problem finding out what read/write speed it have, using a kickrom 2.x (version 37.350)
Interested in one ide68k board.
Sending PM
-Rontti
*payment sent and item received. Leaving positive feedback.
I guess more than a few hundred but less than 1000 KByte/s.
Thanks. :-) If it is above 300kb/s, then it is good enough for me. If it is somewere between 500kb/s and 800kb/s, then I will be happy. I clearly remember that a computer that I had in 1995, transfered around 800kb/s and that was good enough for me. Anything above that are luxury in my eyes, as this is way faster than the average standard conmputer would transfer around 1991/92.
Recieved, and have begun to read up on the installation of this adaptor. I have no time to do the actual installation before next week.
I have one quick question, regarding installation of the two jumper wires on the v425 that I bought. I am having a bit of doubt, as to if I am reading it correctly, and want to ask this, just in case that I do not fry something.
The board need to have /OVR and /INT2 wires installed between the systemboard and the adaptor it self. And is it correct, that I need to use the two pins on the far right, that should be used? In other words, do I have to attach the jumper wires on pin4 and pin5 on the adaptor? Pin4 for /INT2 and Pin5 for /OVR.
Mkl,
I'll take one of the 8Mb RAM cards for the 68000 (V68 ). I want to give this a try on my A2000 with TF534.
Send me a PM with you paypal account details and I'll send you payment via paypal friends option.
Thank-you.
Hi. If it has 5 pins. If 6 the one far-right is an extra ground contact. In v425 board, the signals on the pins should be marked on silk screens on pcb.
Mkl,
Thank-you.
Payment sent.
