Sold Prelude Half Zorro Card SUMMER DEAL
Interested in one please
(Marked as sold/completed by AmigaDigital)
thank you , i put you on the list
To clarify I'd like both the Prelude and the Mpeg-it. I might need the cable to the rear I/O plate to be slightly longer as the Prelude will have to sit in the top Zorro slot in my A4000, but the I/O will probably be 2nd slot up (above the Mediator) and below my Radeon. I'll have measure later.
sure thats no problem , i make the cable longer for you
Interested in a complete version, including mpegit and if I could have the cable long enough to put in any slot in a 3000D that would be great!
Awesome idea!
Awesome idea!
Thank you, i will put you in the list , and the cable are 20cm , so you can use a out slot to place the bracket
full set, declaring interest, targeting an A3000D with AA3000+ mobo and Firebird riser card (if that matters)
Had a quick play this morning. Couldn't get the card to show in my A4000 (with Mediator Mk IV). Removed all other Zorro cards and tried other slots, but still no joy :unsure: Then tried it on my A500 with Matze ZII adapter and again couldn't see the card in early start-up :( Finally tried it in my A3000 and the card was recognised :), but then ran out of time to start installing software/drivers. My intention is/was to use this card in my A4000. Anyone else using one of these in an A4000 with Mediator? Will be tomorrow evening at the earliest before I'm able to have another play.
you got pm
