RAM Tester for Commodore 8-Bit, Amiga & Retro Systems
Featured in Hackaday & Elektor Magazine
Fast, precise, open-source DRAM tester for classic CBM RAM chips found in C64, C128, Amiga (500/1000/2000/3000/4000), Atari, Apple IIe, ZX Spectrum, BBC Micro and many more vintage systems.
Key Features:
- Tests 20-Pin ZIP RAM (DIP and ZIP packages)
- Verifies Static Column functionality
- Measures actual retention time (2-16ms depending on chip type)
- Complete test in under 15 seconds
- One of the fastest Arduino-based solutions available
Open Source Hardware & Software
This is an open-source project – schematics, PCB files, and firmware are publicly available:
GitHub: https://github.com/tops4u/ram-tester
Build your own or order a partially assembled kit from me.
Two Versions Available:
Kits sold here are the SMD USB-C version with all SMD parts assembled, programmed and tested. You only need to solder the through-hole components (ZIF socket, Display, DIP switches, ZIP sockets).
What Makes This Tester Special
Most Arduino-based DRAM testers need 2+ minutes for a single 41256 RAM and check only basic functions.
This tester completes a comprehensive test in 15 seconds or less including:
- Memory cells with various patterns (each bit tested at least 6 times)
- Crosstalk testing (rows & columns)
- Address lines & decoder verification
- Retention time checks (row-wise, twice with random data)
- Ground shorts detection
- Static Column functionality
- Fast Page Mode functionality
- Row Refresh functionality
- Refresh Counter functionality
Speed Comparison:
Other Arduino testers use slow DigitalWrite commands (4µs per bit = 100µs minimum per cell).
This tester uses direct port commands (62.5ns for 1-4 bits) making it up to 60x faster.
Supported RAM Chips
DIP Package (16/18-Pin in ZIF Socket):
DIP or ZIP Package (20-Pin):
For a complete compatibility list including specific computer systems, see: GitHub Compatibility List
Test Times
All times from reset to completion with display enabled:
Safety & Ease of Use
Protected: Resettable fuse protects the tester if a chip shorts out
Simple Operation:
Demo Video:
Watch the tester in action on the GitHub project page (link above).
Documentation & Resources
Complete documentation available on GitHub:
4116 Adapter Board
The 4116/4027 RAM chips require special voltages (+12V, -5V) that the main tester cannot provide. An optional adapter board is available that:
- Generates required voltages safely (current-limited to approx 30mA)
- Includes LED indicators for voltage presence
- Features latch-up protection
- Designed for safety with sensitive 4116 chips
Price & Shipping
What's Included:
What You Need:
Note: Orders ship from Switzerland. Import duties and/or VAT may apply depending on your country.
Availability
Currently in stock: 10+ RAM Testers / 10+ 4116 Adapter Boards
Important Information
Laboratory / Development Tool – Not a Consumer Product
This RAM Tester is supplied as a kit / development tool:
Devices of this product may be returned to the developer for voluntary recycling. Shipping costs are borne by the sender. No participation in any national WEEE take-back scheme is claimed.
By purchasing, assembling, and using this kit, you confirm that you understand and accept these conditions.
Q&A
Q: Do I need to choose between ZIP and ZIF sockets when ordering?
A: No. Every unit includes both socket types. Only one can be used at a time during testing.
Q: Can this test static column RAM like 514402 or 514258?
A: Yes. Firmware v2.3.0+ tests both types and verifies static column functionality. If static column mode is not detected, it automatically falls back to testing as Fast Page Mode.
Q: What about the 4116 adapter board?
A: The 4116/4027 chips require +12V and -5V supplies. The adapter board generates these voltages safely and includes protection features. It's sold separately and requires the main tester to function.
Q: How does this compare to other testers?
A: Most Arduino-based testers take 2+ minutes per chip and only check basic functions. This tester is 8-12x faster and includes retention time testing, static column verification, and comprehensive address/data line checks.
Community Design
Additional Resources
Feel free to contact me with questions or for bulk orders.
Key Features:
- Through-Hole Version (Micro USB power – ideal for DIY builders)
- SMD Version (compact, USB-C power)
Speed Comparison:
Supported RAM Chips
- 4027 (4K x 1) - 2ms retention test (requires adapter board)
- 4116 (16K x 1) - 2ms retention test (requires adapter board)
- 4816 (16K x 1) - 2ms retention test
- 4164 (64K x 1) - 4ms retention test
- 41256 (256K x 1) - 4ms retention test
- 4416 (16K x 4) - 4ms retention test
- 4464 (64K x 4) - 4ms retention test
- 411000 (1M x 1) - 8ms retention test
- Preliminary 4532 / 3732 (Half-Good 4164 used in Spektrum)
- Upcomming Nibble Mode for 41257
- 44256 / 514256 / 514258 (256K x 4) - 16ms retention test, Static Column support
- 514400 / 514402 (1M x 4) - 16ms retention test, Static Column support
Test Times
- 4027 / 4116 / 4816: 2.9 seconds
- 4164: 4.6 seconds
- 4416: 3.9 seconds
- 4464: 6.7 seconds
- 41256: 12 seconds
- 514256: 5.9 seconds
- 514258: 6.2 seconds
- 514400 / 514402: 16 seconds
- 411000: 37 seconds
Simple Operation:
- Select chip type using DIP switches (16/18/20 pins)
- Insert chip into appropriate socket (ZIF or ZIP)
- Connect USB power
- Press reset button
- Read result:
- Yellow LED: Testing in progress
- Green + Yellow flashing: PASS
- Red + Yellow flashing: FAIL
- Display shows detailed results
Demo Video:
- Assembly Instructions: GitHub Docs Page
- User Manual
- Schematic & PCB files (KiCad format)
- Firmware source code
- Changelog & updates
4116 Adapter Board
Price & Shipping
- RAM Tester Kit: 25 CHF
- 4116 Adapter Board: 10 CHF (requires main tester)
- Shipping:
- Switzerland: 2 CHF
- EU: 4.50 CHF
- Worldwide (except USA): 7.50 CHF
- South America: 14 CHF (registered mail only)
What's Included:
- PCB with all SMD parts pre-assembled
- Programmed and tested ATmega328P microcontroller
- All through-hole components (ZIF socket, OLED display, DIP switches, ZIP sockets)
- Assembly instructions leaflet
- Self-adhesive foam rubber pad for completed PCB
What You Need:
- Soldering iron (50 solder points total, 36 for 4116 adapter)
- USB power supply: 5V 1A with USB-C cable
Availability
- Intended for laboratory and development use only
- Not designed for household or consumer applications
- Requires soldering skills to complete assembly
- Use at your own risk – no liability for damage to equipment, property, or injury
- No warranty – sold as-is after testing
- Not responsible for damage from misuse or faulty chips
Q&A
Community Design
- Also available on Tindie: https://www.tindie.com/products/tops4u/ram-tester/
- Also available on eBay: https://www.ebay.ch/itm/136743995188
- DIY at PCBWay: https://www.pcbway.com/project/shareproject/Ram_Tester_ThruHole_Version_93863356.html
