commodorejohn
Shameless recidivist
Hey, we've finally got a programming forum! I've been waiting for this, so now's a good time to do a write-up on my current programming project: a game engine for 16-bit computers. I've been scheming this up for some time now, but it's only recently that I've made real progress in nailing down the design. I plan to use this thread as a sort of running development journal as I move from design to implementation to the development of a test game. (I will be doing a full-fledged game for this eventually, but that'll have its own thread.)
So, the project. As I said, it's a generalized 2D game engine designed to run on fairly low-end 16-bit computers. I have two specific targets in mind: 8086 PCs and OCS Amigas. (I may also do other ports, but these are lower-priority.) I will also put together a portable, SDL-based version of the engine that can use the audio and video engines from any machine-specific version, for the lazy schmucks who just want to run it from XP or whatever.
General goals
Amiga baseline - One of my key goals here is for the other versions of the engine to be either cut-down or enhanced versions of the Amiga engine, rather than the Amiga version being a cut-down or marginally-enhanced port of something else, as was too often the case back in the day.
Low requirements - The engine should be designed to keep the requirements for playable operation as low as possible without compromising the game experience. In other words, it should impose as little overhead in memory and CPU usage as possible.
Uniformity of game experience - While it's not really possible for the game to be identical across all target systems, and while it should be possible for the engine to make the game to look and sound a little nicer on more capable systems, the game should, overall, play the same on all targets.
Distinctive tailoring of graphics and sound per target - Though it seems like a contradiction of the above point, the game should take specific advantage of whatever hardware it's running on. The game should play the same across all systems, but it should look and sound a little different on a VGA PC with an Adlib than it does on an Amiga, for example.
Flexibility and ease of use - The engine should be flexible enough to be used for more than just one game; it should provide general capabilities that game-specific scripts can make use of in whatever way works best for them.
OS friendliness - As someone who spent a number of my formative computing years trying to get games to run on a Windows 95 machine, and consquently, formatting a lot of DOS boot disks, I appreciate it immensely when a game works alongside the host OS rather than hijacking it. While it may not be feasible on some targets and may not matter on others, as a general rule the engine should do its work through the facilities of the operating system whenever possible.
Potential targets
These are the systems that I'm thinking of running the engine on. As stated above, only the Amiga and the PC are guaranteed targets, but any of these may potentially see a port:
Graphics
The engine is geared towards moving variable-sized graphic objects around in tile-based maps, for the most part (there will be some support for both bitmapped and vector-based backgrounds, but these are more intended for menus and cutscenes than for gameplay proper.) Support for a fixed-position, fixed-size status window is also provided, though it can be turned off and status information displayed via graphic objects, at the discretion of the game designer.
Since the goal is for the Amiga version to be the standard, the engine will generally be arranged around OCS Amiga capabilities. Specifically, the default, ideal graphics mode will be 320x200 with 32 colors and a 1-bit "shadow mask" to provide simple lighting effects - in other words, Extra Half-Bright mode.
Systems with 256 colors (VGA PCs, high-color Macs) can be enhanced with a more detailed shadow mask (a 3-bit shadow mask, specifically.) Systems with only 16 colors, on the other hand, will use a customized set of 16-color equivalents to the normal game graphics. These should generally be arranged around the common RGBI palette, a.k.a. the EGA/Tandy color set, but support will be provided for tweaking these colors on systems that support it (EGA PCs with EGA monitors, 16-color Macs, etc.) 16-color mode will probably ignore the shadow mask.
Sound
Sound is a little different, since the Amiga hardware is not quite ideal; sampled instruments are nice, but having only four channels can be a pain. Therefore, the Amiga version will use specific 4-channel versions of the game music, which can be tweaked to fit as best as possible (i.e. combining chords onto a single channel,) while systems with higher polyphony will use a multi-channel version of the soundtrack (to allow for the possibility of a Sega port, I'm thinking six channels, but we'll see.)
The Amiga 4-channel version of a song will just use samples, but the multi-channel version will use notional instruments that are translated to the appropriate sounds for the target hardware. In other words, the "guitar" instrument for a song is loaded from the game's instrument bank in the appropriate format depending on whether the music is played on an OPL2/OPL3 sound card, the Sega's OPM chip, the Macintosh Sound Manager, or whatever.
Sound effects can come in both sampled format and PC-speaker type format (that is, a series of pitch values for a square-wave output.) Most versions, when possible, will use the sampled version, but some targets may not have sampled channels available, and will use the PC-speaker version instead. Sound-effect polyphony and priority are entirely dependent on the target system.
Of particular note in the audio department is the Tandy. It has four channels in addition to the PC speaker, but unfortunately, they produce only three square waves and a white noise channel, not samples. I'm undecided as to whether to provide for another custom-fit version of the soundtrack, or just feature four-voice polyphony for PC-speaker format sound effects. The Sega Genesis version will do that for sound effects, since it has a basically-identical sound chip included, but also has a six-channel Yamaha FM chip for the music.
Game logic
The actual game part of the game is geared towards multiple independent script objects all running simultaneously. The basic idea is that each object in the game (the player, the enemies, projectiles, etc.) is represented by a script object, which is comprised of the script code (which can be shared across identical objects) plus an area of RAM for script data (which is unique to that individual game object.) There is also a shared area of RAM for global game data. Much of the non-game logic (menus, cutscenes, etc.) is handled by script objects as well; in fact, the engine as a whole is basically a giant implementation and management layer for the script API. The scripting language is essentially a sort of ersatz Forth, which I'm using because it's memory-efficient and the easiest thing in the world to write a compiler for (as well as being ridiculously easy to implement on the 68000.)
The script compiler will support a simple form of inheritance. Each script can have a parent script (however, the parent script cannot have a parent script,) and can use all of the code defined by that parent script. In addition, every script can use code defined at a global level, which will include the API for controlling the game engine as well as some basic support-library functions (accelerated math/trig functions, etc.)
Script objects can pass messages to each other by pushing arguments onto the recipient's data stack and calling the appropriate subroutine in the script. This is done through the engine, which first checks to make sure that the target object is allowing messages from the sender. The engine can also pass messages to a script, which is used for things like collision detection.
Implementation
The way I see it, the implementation of the game engine is divided into six major components, some of which have additional sub-components:
Memory manager
Depending on the platform, this may be a simple wrapper for OS APIs, or an actual (if simplistic) memory manager. Its job is simply to handle allocation, deallocation, and relocation/garbage-collection of objects, resources, and work memory as simply and quickly as possible.
Resource manager
Keeps track of what game resources are loaded into memory; relies on the memory manager to keep track of where. Handles loading of resources from disk and saving of game state. (This works slightly differently on ROM-based targets; only game/object data is actually loaded or stored, and all other resources are kept in ROM.)
Object manager
Handles spawning and killing of game objects, message-passing between objects and other object-object interactions (e.g. collision detection,) and decides object execution order.
Sub-components:
Handles input from the keyboard, mouse, and/or joystick/gamepad, translating key presses, movement, and button presses into generalized events that can be handled by scripts.
Graphics engine
Handles drawing operations. It has has five essential functions: drawing a scrolling window comprised of 16x16 tiles, drawing graphic objects into that window, providing simple vertical prioritizing for graphic objects to allow for pseudo-3D game layout, overlaying a static window onto the screen, and drawing text and graphic objects into the static window. On hardware with higher color depths, it also provides shadow-mask capability for lighting effects.
Sub-components:
Handles conversion of game sounds from note/instrument information provided by its sub-components into hardware-appropriate sound data.
Sub-components:
Conclusion
And that's basically it for now. I'll be posting updates as I make progress on more detailed design goals, individual implementations, and development tools.
General goals
Potential targets
- OCS Amiga
The standard equipment the engine is designed around. 7.16MHz, 512KB of RAM, 320x200 resolution, 64 colors out of 4096, and four channels of sampled sound (not to mention some very handy hardware and firmware for making use of all this.) - 8086 PC
Something of a wildcard. 320x200 resolution is still guaranteed, but the rest of the hardware can vary quite a bit. It can have 16 fixed colors, 16 colors out of a palette of 64, or 256 colors out of a palette of 256,000. It can have only one channel of simple square-wave output, nine channels of two-operator FM synthesis, nine channels of four-operator FM synthesis, and/or one channel of sampled sound. The CPU speed can vary from 4.77MHz to multiple gigaherz. And the amount of memory can be anywhere from 64KB to 640KB (though the latter is definitely more common, and it's unlikely that any non-test games will be running in less than 128KB.) Needless to say, game experience may vary significantly. - Tandy PC
Basically like any other PC, but the video hardware is always at 320x200 with 16 fixed colors, and there is a sound chip that produces three channels of square-wave output plus one channel of white noise. The CPU speed is almost always within 4-8MHz, but I'm not sure whether that will be enough, since the video hardware provides none of the assistance that the EGA/VGA cards provide. - 68k color Macintosh
A lot less hardware-focused than any of the other targets; just about everything is done in software, so a Mac version will probably require more CPU oomph to run acceptably. Not too different from the Amiga otherwise; a 68000 running at 8+ MHz, 512KB+ of RAM, either 16 or 256 colors out of a palette of 4096 or more, and 320x200 possible either by letterboxing (on a 512x384 screen) or pixel-doubling (on a 640x480 screen.) Sound can be one channel of sampled sound (Sound Manager 1-2) or an indefinite number of channels (Sound Manager 3+.) - Sega Genesis
An interesting piece of hardware. The 7.67MHz 68000 means a lot of Amiga code can be re-used, and the tile-and-sprite-based video hardware fits nicely with the general design of the graphics engine, but while the video chip does provide 64 colors (out of a palette of 512,) they're divided into four separate 16-color palettes, and the system has only 64KB of RAM. This isn't such a huge problem, since most game resources will work fine off a ROM cartridge, but it does limit the number of script objects that can be active at once. Features a Yamaha OPM chip with six channels of 4-operator FM synthesis and a Tandy-style PSG, plus a Z80 to help drive them. - Sega CD
The Genesis, unfettered. Adds 512KB of RAM, a second 68000 running at 12MHz, some kind of graphics-accelerator chip (not real clear on its capabilities, I need to go over the documentation again,) and eight channels of sampled sound, plus that whole CD thing (read: 650MB of storage, also usable for Redbook audio.) The documentation is cryptic, but it's definitely powerful.
Graphics
Sound
Game logic
Implementation
Memory manager
Resource manager
Object manager
Sub-components:
- Script manager
Executes object scripts as directed by the object manager. (Generally not an interpreter, as the scripts will be compiled to native code wherever possible, but that probably won't work on the Windows XP version, and may not even work on a Mac.) - Object API
Provides an interface between the other engine components and game objects, as well as handling message-passing between objects, and providing a library of accelerated operations for scripts to use (mathematical functions, collision detection, etc.)
Graphics engine
Sub-components:
- Vector rasterizer
Used for cutscenes, this component draws shapes from solid-color polygons in place of a tile-based background. Graphic objects and the static window may be overlaid onto this background just as with the tile-based backgrounds. - Graphics loader
Decides which representation of game graphics to load from disk based on what video hardware is present. Converts between graphics formats when necessary (though as much of the conversion as possible should be done at production time.)
Sub-components:
- Music player
Handles playback of game music, outputting note/instrument information for each channel to the sound engine. - Sound-effect player
Arbitrates between sounds effects of higher and lower priority when sound-effect channels are limited, and outputs note/instrument information to the sound engine. - Instrument loader
Loads the appropriate instrument resources for the sound hardware.
Conclusion
