I've finally managed to get a solder station or more accurately a desolder station - which is far more important to me.
A Duratool desolder station (Farnell / RS)
80 wat , 240v, 24v desolder torch.
The torch can be replaced as its listed in the accessories in the farnell catalouge.
The kit cottons the following.
Pump unit (240v)
desolder torch
some files
3x tips
power lead.
Setup is easy and in 5 mins you are ready to go - set the temp and away you go. i have found that around 350c is good but it depends on the size of component and the type of track/pcb its on. Big tracks & big components = more temp. smaller stuff is easily done with a lower temp.
Flux is also very handy when removing stuff as it allows the solder to run away. You may find that the pins of components are often leaning on the side of solder hole, you can move the pin gently with the torch to centralise it.
so a test component was chosen and quickly removed to proved pics and then replaced - i was lazy and used the desolder tool to solder too.
total time - 5 minutes from removal to refit.
easy, simple and non destructive to the board if you use the correct sized tip (hole size)
mike.
Overall.
heating up speed - very quick.
suction - good.
ease of use - excellent, simple & quick.
i should of got one years ago.
mike.
Quick vid
http://youtu.be/KZSGdxo0CkQ
Pump unit (240v)
desolder torch
some files
3x tips
power lead.
mike.
Overall.
suction - good.
mike.
Quick vid
