Closed SID 6581 - 8580 replacements
  • Thread starter Thread starter tony1999it
  • Replies Replies 364
  • Views Views 84310
So how would I put it in my C64? It has an 8680, but like the 6581 better... I was told the 6581 voltage is more?
I assume you mean 8580. And yes, the 8580 SID runs with a lower supply voltage, so you need to modify your C64 board to provide the higher supply voltage before the 6581 will work. The filters in 6581 also needs some other filter capacitors or it will not sound correct. Compare the schematics of the two to see how you could do these modifications. If you are unsure about doing this change, I would probably stay away from it since you could easily burn the SID if the supply voltage is too high.
The Swinsid doesn't use the high supply voltage. It just uses the 5V supply so it will run in any motherboard without modifications (it also uses its own filters).
Hi Tony,
I would be interested in two units if still available. Registered/trackable mail to Italy- thanks a lot
bye
illobo
Mine arrived yesterday well packaged and looks good. I will try it out after work and leave feedback :thumbsup:
Perfect! I got the chance to try it out yesterday and it worked fine. Just left POSITIVE feedback :thumbsup:
Hello
Are you planning to build some SwinSID *Ultimate* version ?
Are the SwinSID nano v.2 are still available ?
What is the price for 1 SwinSID nano v.2 shipped in France ?
Same question with 2 SwinSID nano v.2 ?
Many thanks for your time and work :)
Hello
Hello
I can assemble the Swinsids nano v2 only.
For France 1 swinsid is 15€ + 3.50€ with ordinary mail or 7.50€ with the registered one.
Same shipping costs for 2 swinsids.
