Is anyone here using this board in their Amiga?
I would like to ask something about the RJ45 adapter that I should buy.
Resources that I've found:
Generic info: A2065
Other info about the ethernet connection and specifications
Here the driver that I should use in Sys: Devs/network
If I well understood the board has an "AUI" connector. It is the 15 pin D-sub port next to the BNC connector. So, in order to use a normal ethernet cable plugged by the common RJ45 I need to buy "an AUI to UTP transceive". Is it correct?
Something like this, right?
Thank you for any responses and support
Generic info: A2065
