WarpUP-WarpOS-Warp3D Noob questions
  • Thread starter Thread starter merlinkv
  • Replies Replies 25
  • Views Views 4495
Hi Steve
Runing BlitzQuake_68k (GLQuake Amiga version 1.31) with P96 at 640x480, 800x600 & 1024x768, all 32 bit. :)
- 1024x768 full screen runs smooth & fast. :thumbsup:
I don't know but I think this revision _68k don't use the PPC engine.
My 68k is running at 66Mhz, Voodoo3 is using 16MB, and system have a laaaaarge amount of Fast RAM >400MB
As I said before my Mediator settings:
VoodooMem = 16
MMU = Yes
VoodooInt = Yes
Warp3D = Yes
Buster = 11
My WindowsSize jumper is in 512mb position because I have also one Radeon 9200 256MB.
Best wishes
Hi!
Still no luck with MMU set = Yes :(
Can you tell me what Libs you have for Warp3D?
Cheers!
Hi Steve
Elbox Warp3D 4.2 68k & PPC, and all libraries for WarUP-WarpOS-PPCLibEmu
I'm running Quake with P96 at 1024x768 32bit, but I have problems with Quake II (I installed today for the first time) .... game start but...... black screen.
Best wishes
Hi Pablo! Thanks again - if you got to SYS:Libs/Warp3D can you list the file names of the libs you have inside each of the two folders?
Cheers!
Hi again
DH0:Libs/Warp3D/GFXdrivers
W3D_Picasso96.library
W3D_Picasso96_PPC.library
DH0:Libs/Warp3D/HWdrivers
W3D_AvengerBE.library
W3D_AvengerBE_PPC.library
W3D_AvengerLE.library
W3D_AvengerLE_PPC.library
I'm running Picasso96 2.2a4
That's all
Hi again
That's all
Thanks my friend, I'll check mine match this - then we have the same settings throughout!
Cheers!
Steve.
---------- Post added at 20:37 ---------- Previous post was at 20:11 ----------
Hi!
Also tried this time without CV64/3D and Mediator in 512mb Window and have all the same files and settings as you. Still no Warp3D working on my A4000 :(
I think I'll return this machine to a Zorr0 setup :thumbsup:
  • Mediator does not fit my case properly
  • LED's are different for this board so not working
  • Cannot use my Z3 Fastlane
  • Cannot use both GFX Cards in 512mb Window
Too many problems to justify keeping it, and without Warp3D working no positives lol!
Thanks for all the suggestions, its appreciated.
Steve.
