Sold XFX nForce 680i SLi Motherboard + CPU+ Graphics card bundle
  • Thread starter Thread starter Tajmaster
  • Replies Replies 33
  • Views Views 5267
phoenixace has dropped interest in this, DJ Echo has come back in the meantime reaffirming interest.
This is now on hold for DJ until 3rd June, however, DJ has said if someone comes in and declares interest in the meantime that he will step aside:)
I also have this motherboard bundle available here: https://www.amibay.com/showthread.php?t=44968
Hey man, I'm interested in this, but just need to research the board a little bit. Do you happen know if this board will run a 3ghz core 2 duo?
I dont know off the top of my head, Ill unpack it and get the manual out to confirm though and post back here:thumbsup:
Taj
Hiya, I'm going to withdraw interest in this.
I'm pretty sure it WILL take an E8400 cpu and looks like a very good motherboard, but there seems to be some doubt about whether it'll work properly with a fairly low-wattage power supply with only a 4-pin 12v connector (rather than the recommended 8pin connection). I could probably try using a sata-molex power adapter and connect that to the board, but it may still struggle.
I was intending to use this to build a cheap half-decent PC for a friend, but if I had to buy a better power supply to run it then it would defeat the object of saving money, so that's the only reason I'm withdrawing interest.
Sorry for wasting your time, I hope you don't mind!
Even if it doesn't a board of this spec should have overclock options that will unofficially be able to set to the required FSB and clock. Only difference being you will have to set the FSB manually instead of it being in a preset.
EDIT: This board appears to support 1333 FSB from factory so it should be fine with all C2D chips.
There will likely have been a BIOS update for it too before now.
Thanks to the above for the info :thumbsup:
PM was sent to DJ Echo on the 3rd but had no response, so this is now available again :thumbsup:
£40 inc free postage
hi
hi
hi still here sorry :oops: for the delay had some paypal issues that should be resolved soon,
Is this still available or still being held for djecho ?
cheers
Hi mate,
I havent heard from Mr DJ for a week, I need this sold so if you want it Im happy to move on to you, I think DJ has had enough time:)
Taj
Happy to go ahead and buy this :)
Am out atm as per pm
will send you funds later tonight
cheers
