ZIP to SIMM adapter for the A3000D
  • Thread starter Thread starter vibros
  • Replies Replies 326
  • Views Views 58871
Hello,
maw2k, if you are still interested your part is ready to be sent. It is already tested for about two days, just to give the right position to the flat pins.
The cost is 40 Eur + 11 Eur of postage to your country.
Another unit is already tested and ready, but without logic, at the cost of 30 Eur + postage. If Astral is still interested, this part is for you: if you can burn a GAL in your area, well, otherwise i can obtain one part and sent it later, at the cost of postage (about 2 Eur), but it take time. The adapter can be sent now, and will see max 8Mb.
Regards
Stefano
Pictured is the part for maw2k, follow soon the pictures of the other part!
Hi Vibros,
I am interested in one with full logic if/when it becomes available. Thanks!
Stefano, I will have to withdraw since I finally buried now the idea to get an A3000. I'm sure esc will be happy to have it. Sorry again.
Also I am going to withdraw interest for now but may be interested in the future! THanks :)
Hello,
the part in picture that was for maw2k, come to Astral at the same price 40 Eur + 11 Eur postage + Paypal fee (or sent as gift).
Regards
Stefano
Hello,
here the second item, without logic, at 30 Eur + postage (the logic can be added later).
Regards
Stefano
Hello,
replied on PM to highpuff.
I wish to add two words about this device.
I hope soon i will release the draw of a two layer version of this PCB, but it will take time, because the layout of the tracks need to be newly draw: the pins used by this new design will be aligned in rows and not alone and sparse like you see on this device for sale, otherwise will be impossible to solder the pins towards vertical and then will be hard to put this adapter in place.
What you see on this sale, has sparse pins, because to obtain this design in a single side board, just a choose of sparse pins allow to obtain the final result that you see in this pictures.
The flat pins, that are flexible, allow a very good handling to insert it in place, but this pins are not on the market, they are made by me from other parts.
If i release the new draw, every person can build his own unit, and need to find all the parts needed to build it, in other words, you will find rows of pins (round or square of section), and only in rows you can solder this pins correctly!
What is here for sale, is made manually, tested for a couple of days, and then packed. The parts are not all the same and can be that some PCB are printed not so good (the tracks can be not so precious, but they are not visible, when the device is mounted), but, if it is here, the device is reliable and protected against oxidation.
The difference of the cost is just the cost of the programmable device and the time spent to program it: you do not pay for the content, that is freely downloadable here on Amibay!
The cost of this device is 40 Eur, with the logic, less without the logic: in this case, 30 Eur.
Regards
Stefano
Hello Vibros, just a little question: your adapter work in A3000T version ?
Because today i have FINALLY repaired my old A3000T (many many hours for search failure) and i want installer your hardware with 16Mb fast ram.
Hello,
no, it does not fit into an A3000T motherboard, because the distance of the two blocks of sockets is diferrent from the A3000D motherboard.
A version for the A3000T is not planned...
Regards
Stefano
