Hello,
item sent today; more on PM.
Hello replied on PM
Regards
Stefano
Hello,
to all interested on this device, please, read carefully:
to install this device, you need to detach the motherboard from the metal case and detach the daughterboard from it. Then, put a light between the zip sockets and the power connector of the motherboard;
take a look at the empty sockets, they need to be in good condition, otherwise with a little flat screwdriver try to make the things better.
Put the device on the sockets (see the pictures on this thread) and carefully press it down. If you encounter resistence, detach it , look at the pins, adjust what need to be adjusted and reput it on the sockets.
Shake it to right and to left, carefully, to feel the right position, then press it: it need to stay about 1-2mm over the sockets. With the help of the light, take a look that no pins are bend.
This device is handmade, but print it with a machinery give a result slight better. The worst part of this work is to solder the pins. On my device the pins are flat and not round, and this thing give a better (for my opinion) contact between the parts.
On the market, i have not found flat pins, and i have made it manually from new parts. they are like nails to avoid to tear the tracks when you detach the adapter from the motherboard.
Last thing, to detach this device, use a flat screwdriver and act around the border.
Regards
Stefano
