ZX 48k Spectrum Display Problem
  • Thread starter Thread starter keitha
  • Replies Replies 12
  • Views Views 3222
You might want to measure voltages for the +5, -5 and +12 Volts pins on all the lower RAM chips. That'll give you pointers where to start looking for the probable cause.
As the Spectrum 48K tend to only have 3 extrememly common problems:
1 - Power circuitry - Check voltages as Protek suggests. If they are wrong then you need to swap 2 transistors.
2 - Lower RAM - Most likely your issue in this case - Replace lower RAM.
3 - ULA dead - Pretty unlikely.
Bryce.
If it's a switching PSU pushing at least 1,5 Amps, you should be ok.
You don't want that one. That one has positive center. You want one with negative center or switchable polarity.
Thank you for keeping me right :D
Appreciated
Bryce.
Thanks :thumbsup:
im curious.
why do you need a power supply if you managed to power it up to take that picture.
did you borrow the supply from another system?
im here if you never manage to find the problem.
could be cpu,rom,or memory,or combination of a couple of things.including a power problem.
im curious.
My Sinclair PS is failing apart, and thought I'd ask about compatible replacements (glad I did)
Appreciate the offer :thumbsup:
