For Sale A500 IDE adapters, PS/2 mouse adapter, A600 CF adapter
  • Thread starter Thread starter mkl
  • Replies Replies 914
  • Views Views 238213
Mika is a very decent guy, he is probably busy. I think your money is not wasted.
Could I buy only the PCB for the CFIDE68K ? Or has a kit (solder it yourself)?
Hi.
I have a few blank PCBs. Price for one is 20 euros.
If you need parts, I can sell these too.
---------- Post added at 01:13 ---------- Previous post was at 01:00 ----------
Feedback left for abraXXious, loth77, imstarryeyed, gibs and craggus2000.
If I've forgotten to give feedback for any item, please remind me by PM.
CFIDE68K
CFIDE68K
I would be interrested in 2 blank boards (CFIDE68k) including parts.
I will do the soldering myself.
Hi.
---------- Post added at 20:02 ---------- Previous post was at 19:41 ----------
Any chance that you have one A600/1200 internal CF-card adapter for sale? Soldering it myself.
If so, what is the price?
regards
Hi.
@Mika: any chance to use a 68H010 instead the 68H000?
68010 should work, I had one earlier version board with a 68010.
---------- Post added at 18:26 ---------- Previous post was at 18:23 ----------
Items I have for sale now are:
Three built v296 boards, one of the three is without a cf-connector.
I'll be home after about one week, where I left some other items.
The cpld's have been programmed in-system, after soldering.
A vqfp-64 ZIF socket for programming before soldering the ic, if such exists, would probably be so expensive that it will be cheaper to get a download (programming) cable and connect it to the 6 pin header on ide68k pcb.
Sorry to bother you sir, but I was curious about when there might be availability on the A600 CF adapter again? I very much like the design and would like to purchase one when you have the availability.
I'm also in the market for a CF adaptor for the a600. I have a suggestion for a minor change in the desing. It owuld be great if the cf would be accessible from without opening the case. Turning the cf 45 degrees would make that possible. You could use the holes in the pcmcia port to mount the card.
This is the solution i would like. Opening all the time the plastic chassis eats
your time and destroys also the poor AMIGA. Maybe with a small cut on the
top of the PCMCIA this might be possible.
OR
If you connect a 60cm 44pin cable and place all round below the keyboard to reach the trapdoor.
With this option you do not have to cut the chassis or worry for mistakes.
I have about 5..7 a600 ide2cf adapters where i changed the 'bad' 44-pin socket.
I have also some new blank revised pcbs for it. Also a couple of ps2m adapters,
and blank pcbs for an atari st version.
And V401 ide68k p.c.boards, which are smaller than other versions, without cf or clockport connectors and 40-pin ide connector moved to to other side of the cpu. (No photos of these yet, but maybe later.)
Support for autoboot ? Any additional connection like the previous versions ?
Hello, I would still be interested in an A600 angled IDE2CF adapter. There isn't a price listed, could you quote me the price and shipping to the US, specifically Kansas?
Thank you,
Nathan
