  • Replies Replies 914
  • Views Views 238213
I've received the pcbs for v402. Can sell panels with ten blank pcbs (v-scored for separation) for 60 euros per panel.
Do you still have these panels for sale ? I am interested in buying one.
best regards
Szymon
Hi yes, 60 euros for one panel.
---------- Post added at 03:52 ---------- Previous post was at 03:51 ----------
Sorry but I have a poor english (and too lazy to read all this post :roll:).
Do you still have some IDE68K for sale ???
I need one for an Amiga 1000 / Ks 1.3.
One with memory expansion will be great too.
Thanks
KS1.3 won't boot it. None of the ide68k boards so far have memory expansion.
---------- Post added at 03:54 ---------- Previous post was at 03:52 ----------
My V402 came in the mail a while ago and I'm just getting around to installing it. Unfortunately I tried to change the DASP/LED connector to try and make it clear the keyboard and wound up completely screwing up the traces pretty badly in the process.
I'm not going to ask about service or anything like that because I entirely screwed this up and it's my fault. However, I'm seeing holes for a secondary LED/motherboard header connector on the other end of the card - will this work just as well?
Yes, these secondary outputs should work too. Have you tried it already?
I noted that the dasp,int2,led pins might not fit in A500 with keyboard.
---------- Post added at 03:55 ---------- Previous post was at 03:54 ----------
Am I blind or is there no price listed for "A600/1200 Internal CF-card adapters to IDE connector" ?
Price for assembled adapter is 20 euros.
---------- Post added at 03:58 ---------- Previous post was at 03:55 ----------
I need a IDE68K, best with memory expansion, for my CDTV, too!
IDE68k should work in CDTV with the right KSROM.
I've only tested these V402 boards on an open A500 mainboard.
---------- Post added at 04:41 ---------- Previous post was at 03:58 ----------
Front post for this for sale thread is now more up to date.
The ide-connector is a 40-pin header, I've used what I think is called a boxed, walled or shrouded polarised connector. Optionally, a plain pin-header strip can be soldered, but wrong insertion can lead to something like burnt cf-card. +5V supply is connected to certain one of these 40 pins.
The four pins for led,int2 and ovr can be a problem :whistle: :
Keyboard in A500 can come too close when case is being closed.
The holes on the pcb are too small to accept "normal" 0.025" square pin header pins, special pins with narrowed solder tails need to be used.
Therefore I'm willing to offer the adapter without pins soldered there,
wires soldered instead of pins,
or with right angle 5-pin header at the other end of the pcb.
I have a lot of new 40-pin ide-cables I can send one for free with the adapter.
I have about a dozen of new-old-stock 64 megabyte CF-cards.
And some used 68HC000 DIP CPU:s, price +5 euros with ide68k.
Hi Mika,
Recieved my v402 ide68k yesterday:)
Only 7 days from Finland to New Zealand
And today installed card(solder 2 wires) and tested working 100%:)
What a amazing piece of hardware!!!:bowdown:
Leaving Feedback
Cheers:)
Secondary /int2 at the back end won't work in v402 boards with 'rev 1' cpld code. (v402 shipped before today) Using 'rev 0' enabled the 2nd /int2 (.jed file available at the www page)
What model of USB-based FPGA programmer would you recommend? As for parallel port solutions, would this work?
Probably it would work.
Most simplest LPT-cable doesn't "need" any parts except wire, or at least I managed to program some 5V XC9572 CPLD's with old PC.
I don't have an USB-based cable yet, but because the newer laptops don't have the LPT port, I've planned to purchase some USB-cable.
About 10 pcs tested v402 boards available. The adapters don't have any pins soldered to the /ovr and /int2 output pads. (The booting from cf card tests were performed while temporarily holding pins in the pcb holes.)
Some are with 40-pin 'bare' headers, others with walled connectors.
Price 40 euros / 1 pce
Shipping 8/10 euros to europe/world per registered mail package.
Packs won't include free ide cables at the moment.
---------- Post added at 11:58 ---------- Previous post was at 11:49 ----------
@mkl
Any chance there will be a new run of PS/2 Amiga mouse adapters?
Cheers,
Winston
Hi. I haven't planned to do so any time soon.
