Here goes another update of my (slow, I know) A4000 restoration project:
Once all mainboard reworks are ok and all zorro cards were all cleaned, now It's time to mess with the Zorro Daghuter Board or Zorro Riser Card, whatever you want to call it.
Well, this one (speaking about cards of this miggy) is the most ramshackled of all, with some scratches over the varnish on the rear side and even some copper corrosion.
Here is a closeup of one of the corrosion areas:
Well , taking in mind that I already have another -never used- spare riser (bought as a NOS part some years ago on the other bay) so, as I've nothing to loose, I decided to fix this and if something goes wrong, I'll have no worries at all.
Fisrt of all I removed all the old capacitors and them, following some wise advices at the AmiOracle section (thanks rkauer, and ZetrO
), I scratched the old lacquer over the corroded areas and then give them some lemon treatment.
Here is the result after treatment and cleaning of all the lemon juice:
As you can see the corrosion was only supeficial so It means that will be easier to fix, and yes if you look closer, that pic shows that I've forgot to scratch and treat two pins at the right, but this was done soon after, so no problem.
Then I've tested continuity and all seemed ok and, following the same advices told before, I've refreshed all the soldering on this areas.
When I re-soldered that pins, some excess solder lead runned over the exposed copper giving it an, at first, unwanted plating effect, but what at first I thought that was a mistake, turned out to be the best thing I could do, as the lead now covers all the copper and protects it better from moistures than lacquer does (some Beginner's luck here).
So here is a pic of the final result of this fixed area now, with new lacquer also:
Well , meanwhile and before applying new lacquer I've soldered new capacitors to it, I was not able to source those locally in Axial type form, so I've adapted those in more common Radial form (A.K.A. thru hole) just bending the rods to fit on their vias (just like I saw it somewhere, on Cosmos' Blog if I remember ok).
Here goes a pic of that area:
Summarizing it, here is the final result on the front side:
And a full view of the rear side with all things done also (note the shiny new lacquer):
And again, I Hope You'll like it, and thanks for watching!
Bye!
