Okay. Came from work this morning and decided to do this one thing before I go to sleep. In the middle of a night shift week but I have to do stuff other than work to stay sane. So, time for a fun little fan change project that I´ve been planning for a while! All the parts are here, so here I go!
CPS2 Alien vs Predator phoenix edition. May be a conversion. Haven´t checked. The real problem is the fan noise.
Here is the main villain. Noisy cps2 a-board fan.
Shipment from Aquatuning to the rescue!
So... off go the clips that hold the a board and b board together.
Here are the boards, now separated
So here´s the replacement fan: a Papst 612fl. Also needed is a special screwdriver head
And while I didnt have a screwdriver where to fit this head, anything that gives a bit of torque will do. Space is not an issue here
The cover lifted up after screwing off all 4 screws
The fan is old and dirty. It comes off by just lifting it off its "tracks"
So then... of course I cant just put the other fan in. The plugs aren´t the same.
So I just cut the cables, molexes won´t be needed, strip the cables a bit from their ends.
Then I like to add liberal amounts of shrinkwrap there, putting it at the ready before soldering the wires. Keeping it far enough so as not to shrink it yet.
Then I kind of wrap the wires together.
Like this...
And then for the part where my hands start shaking...
Soldering the wires together! Simple task for most people, big deal to my shaky hands.
The results, well... Not pretty, but they´re stuck together, damnit. That´s what counts!
They will probably conduct electricity too!
So I then slide the shrinkwrap on top of the soldered parts. I have only two hands so I´m not taking photo of the part where I put a burning match near the shrinkwrap
After burning two matches, the shrinkwrap has shrunk. It will stay put.
So it is time to slide the new fan in there!
It fits like a glove!
Better remember to put the plug back in too.
And then its just a matter of putting everything back together...
With cover, screws and the little clips connected, it is time for a comparison video!
Here you can hear the dramatic difference between a stock CPS2 fan and Papst 612fl:
http://www.youtube.com/watch?feature=player_embedded&v=FVn9Dw14H2Y
