Basic Guide on Setting up a Prometheus (Firebird) Daughterboard on A3000 and A4000 now here on Amibay
  • Thread starter Thread starter Boing-ball
  • Replies Replies 110
  • Views Views 9710
I tried to run it with Thor's PCI library too, but with the same result.
I found in PCI-Configuration that my board is ignored on pci initialization. I tried to comment out this lines but it didn't help. Maybe there are some known issues...
I asked on EAB and waiting for answer.
Thanks @jargo
Hi, Can you help me? Why does Prometheus appear disabled for me if I've followed all the steps in the guide?
I have the Amiga 4000d with a BFG9060, and I have installed a 3DLabs Permedia 2V PCI 8 MB card.
Does this card show up when running the “lspci” command in a shell?
Which version of the OpenPCI.library are you using? Use the version OpenPCI.library command to check.
lspci doesn't work for me, but an app I found, prm scan, gives me that data.
lspci doesn't work for me, but an app I found, prm scan, gives me that data.View attachment 2565407
Okay.
So you are not using a setup with a PPC PCI card?
If not then go for the latest Thors open PCI Library. From here
Use the install script included. This will then install the lspci command into c drawer
Reboot
Try a reinstall of the Icomp p96 software. Choose the permedia2 graphics card. Do not rename the “permedia2” monitor file.
Reboot
Now try lspci to check that the RTG card is seen.
Then try the P96 preferences to setup.
Good morning, the permedia2 graphics card does not appear in the Picasso 96 installation.
Looking at your lspci output. The RTG card (Permedia2) is not being seen in the list of pci cards. Therefore p96 will not see it either.
You will need to either;
Try the Permedia in another pci slot for it to be recognised
Try the Permedia on its own (remove all other pci cards) to establish you have a working graphics card
Try extra power on the Prometheus Daughterboard with a molex connector
If any of the above don’t work. You may have a faulty permedia2 card.
Thank you so much. It was the Permedia2's fault. I installed a Radeon 9250 AGP with an @bfgmatik adapter, and after installing everything, it detected it on the first try. 👏🏼👏🏼
