Re: Bought a new computer (WAS: Powerfull mATX PSU?)
@Kin Hell
Thanks, I appreciate that. And the Lian-li case you linked to there seems like a pretty little box!
Now in regards to aluminum cases, I have a bad experience with them (a lian-li box incidentially), they do make more noise than their steel counterparts. HD noise in my old case was bad. And using rubber screws/feet only acted as a thermal barrier for the HDs, so they ran much hotter.
From
SilentPCReview:
spcr said:
ALUMINUM
The Aluminum Myth - Some favor aluminum cases, citing an ability to better cool components mounted within. This is a myth. No heat producing component benefit in any significant way from being inside an aluminum case. The only heat producing devices that are normally mounted in direct contact with a case are the drives, particularly the hard drives. The difference between aluminum and steel in this cooling function is insignificant.
This does not mean aluminum cases cannot be used to make a silent computer, just that there are disadvantages with them when compared to similarly constructed steel cases. Regardless, many aluminum cases certainly look nice.
The Aluminum Drawback - One consistent acoustic property seems unavoidable: Aluminum cases tend to pick up hard drive and fan vibrations more readily than steel cases, and make a higher pitched, more audible humming or buzzing sound. This quality is directly related to the density of aluminum: It has only about 30% of the density of the cheaper, more commonly used steel. Internally applied panel damping materials (especially the heavier kinds) appear to damp the resonance down fairly effectively, but it can be difficult and expensive to eliminate entirely. Internal supporting cross braces that effectively divide the large panels into smaller ones also help quite a lot because smaller panels are more rigid, stiffer, and less prone to lower frequency vibration than larger ones.
In the
tweaktown review the guy is commenting on the PSU vs CPU placement in the SG04:
tweaktown said:
Fast forward a bit and I have most of the major components installed and the chassis wiring in place. The cooler for the CPU will accept a fan to aid in cooling, but due to the configuration of this chassis, there just isn’t any room. It will cool slightly passively, but the PSU fan will draw heat off of it, which you will see. Oh, and yes, that is a GTX 280 in there. With the right motherboard I could have even installed two of them for SLI or Crossfire horsepower.
Now he's using a stock clocked E6400 in that build, it's a processor which is reported to idle at 30 with the stock cooler. The Intel i7 950 idles at about ~35 to 40 degrees with a stock cooler.
I'm not going to passivly cool the CPU, and I'm also not using the stock cooler.
So I'm expecting it to be somewhat better. Also, overclocking in a SFF cabinet is out of the question!
I agree that the Lian-li case will have a much better airflow than the SilverStone sogo SG04b, but I'll give it a go first. And if I hit problems I'll swap it for the Lian-li case.
Since the local guy from Amiga.org stiffed me of money and a cabinet, I'm putting further investments on hold atm. BTW, if anyone wants to know who the crook is to avoid him, PM me and I'll share.
