CS MKII 100mhz
  • Thread starter Thread starter Kawazu
  • Replies Replies 48
  • Views Views 6991
Could the ppl that have MKII running 50-75mhz with memory synced post some time demo from adoom?
Start adoom from shell with these.
-forcedemo - timedemo demo 3
I can do this later this week, once I'll get a card. Actually I can run this test for 50/66/75.
Please also add -cpu 68060 -mmu switches. You should get few extra fps. I also suggest screen mode PAL lowres full screen.
Not relevant for our tests but here are some results for A3660@66Mhz:) (16MB Fast ram onboard + 256MB ZIII BigRam Plus) The results are very poor - we can see how much fast ram on cpu board comes into play for fps games even though overall WB experience is very nice.
Soon I'll test it with MK2.
A3660@66MHz PAL lowres 7,9 fps (without -mmu and -cpu 5,7 fps)
A3660@66MHz CV64 320x200 8bit 8,4 fps (w/o -cpu and -mmu 6 fps)
btw
Is's kinda funny that we're using PC game to benchmark Amiga:)
CSMKII @ 75Mhz, in 060 mode, with -cpu 68060 -mmu switches 29.1 fps, without 28.9 fps
I'm not sure you're comparing the same demos - the guys above are using Doom2.
66mhz Cyberstorm mk2: 21.9fps
Here are new benchmarks with all the "extras" used like -mmu -cpu, both Doom and Doom 2 where used.
To sum it up a bit.
wmsteele: MKII@75Mhz
Doom: 29.1FPS
Hal: A3660 @ 66Mhz
Doom: 8.4FPS
trixster: MKII@66Mhz
Doom 2: 21.9FPS
Kawazu: MKII@100Mhz
Doom: 33.6FPS
Doom2: 26.2FPS
DOOM2: CSMKII @ 75Mhz, in 060 mode, with -cpu 68060 -mmu switches 23.2 fps, without 22.6 fps
Doom: 29.1FPS
Doom2: 23.3FPS
Hal: A3660 @ 66Mhz
Doom: 8.4FPS
Doom2: 21.9FPS
Kawazu: MKII@100Mhz
Doom: 33.6FPS
Doom2: 26.2FPS
Great job :)
Is there anything else we can benchmark so we can give the community more numbers if they are thinking about going 100mhz in 1:2 memory on the MKII or not?
Great job:) I was rather thinking that we'll get more fps on @75 1:1 rather than @100 1:2. Surprise surprise:) Time to test my Rev6 006 @100Mhz:)
Indeed, I'm thinking of giving the 040 mode a go myself, looks like running at 100Mhz with 1:2 isn't that bad... wonder if anything higher would be possible :?
When great minds work together :)
I have not seen any one go over 100mhz yet but who knows. Maby you just need to slap a 110 oscillator on there and it's rdy to rock :D
Just not to make things easier:) Finally I was able to test with my MKII. Still looks like @100MHz is the fastest, but what I've noticed is that 68060.library version makes a difference. With the latest Phase5 library I'm getting much better results, comparing to Thor's MuLibs. CV64 results just ignore.
Doom: 29.1FPS
Doom2: 23.3FPS
Hal:
A3660 @ 66Mhz
Doom 2: 8.4FPS
MKII@50Mhz
Doom2: 17.9FPS P5 Libs
Doom2 CV64 (320x200): 20.8FPS P5 Libs
MKII@75Mhz
Doom2: 24.7FPS P5 Libs
Doom2: 21.9FPS MuLibs
Doom2 CV64 (320x200): 30.5FPS P5 Libs
Doom2 CV64 (320x200): 26.1FPS MuLibs
AmiQuake (timedemo demo1): 14.3
A4k IDE speed: 2.56MB/s
Doom2: 21.9FPS
Kawazu: MKII@100Mhz
Doom: 33.6FPS
Doom2: 26.2FPS
P5 Libs: http://phase5.a1k.org/files/68060-19101999.lha
MuLibs: http://aminet.net/package/util/sys/Mu680x0Libs
Can someone benchmark hard drive speed using cyberscsi at 50 and 100mhz? Then compare to using whatever onboard amiga ide/scsi is available.
The important thing for me is being able to use cyberscsi which makes 100mhz a great choice.
Sent from my iPad using Tapatalk Pro
Weird, i tried to do some more time demos but now the demo is just restarting after its finnished.
Before it automatically ended the time demo and i was kicked back to WB but not now, any sugestions?
I don't have SCSI setup but did some tests with a FastATA 4000 MK-VI a while back, these were using an old 30Gb Maxtor diamond max drive...
50Mhz60Mhz66Mhz75Mhz
MIPS66.4779.7687.7699.94
MFLOPS26.5631.9035.0839.88
IDE Create File5.766.206.256.29
IDE Write File6.246.596.726.86
IDE Read File5.716.386.646.81
IDE Raw Read5.426.106.296.42
I'm now using a SanDisk Ultra compact flash 30Mb/s which at 75Mhz performs as follows...
75Mhz
IDE Create File6.18
IDE Write File6.42
IDE Read File7.01
IDE Raw Read7.08
Wow, you got way better speeds then me, I can only run pio3 on my 2.5" 120gb WD disk
i dont think the scsi runs at 100mhz,i think its the same 50mhz
john will probably confirm
i think 100mhz is about 130 mips
