Has anyone got a source for the 2.5" 44-way IDE connector? I've got a straight plug, but really I want a right-angled socket that I can use to plug a drive straight into.
If you mean component part X25, the 22pin 2mm x2 row female, I was planning on getting one of this 25-pin connectors and cutting it down
http://www.reichelt.de/Female-Conne...ARTICLE=6081&GROUPID=3221&artnr=BL+2X25W+2,54
[edit - just realised this is a 2.54mm spacing and not 2.00mm]
OD
Well, I had a long hard look around and these are pretty hard to find. You could always check auction number 181116298035 on the other bay and see if you like that, it has the correct pitch (I believe) and is also raised the correct amount off the board ensuring easy soldering and that the hard drive will fit correctly (hopefully). It looks like the support pins at each end will have to be snipped off as holes for these are not present on the GBA1000 board.
Somewhat expensive after shipping but looks like it will give the desired effect with a little work.
Powered up first time - great news
I think I can do the GAL programming but can I ask how did you get the lsi1024 programmed?
Everything working perfectly, nothing wrong with the board at all. All my problems caused by myself - 32GB Compact Flash sorted the HDD issue. The board definitely doesn't like a 160GB IDE HDD.
Now to install into an A1000 case and get working on the addon cards.
Does anyone have the JEDEC-files for the GALs and the CPLD? I can't find them anywhere. Help please!
