I can't remember where I read it but aren't some TI Chips not compatable due to voltage i.e., being 3.3v
@BlindGerMan might be able to shed some light or guidance here
Good news that it works! Remember to keep the fpu removed, it won’t work at 50mhz. Also check your 5v line - the GG will become unstable if this is too low. In my A3000 anything below around 4.65v starts to cause problemsYes - it’s a bit unstable though once I enable clock doubling to 50 MHz. Might be the CPU or my RAM sticks, but in general… yes, it starts and works.
That won’t work as it’s lacking HALT.Nice to learn and to have this file.
Perhaps now the GG386 could work with the clipon Cyrix 486SLC2 upgrade or is it still a problem with the AMD 386 lacking a signal for it.
Hopefully the patch will work for you.Now this is interesting and possibly helpful! I also have a GG386 which is upgraded with a 486SXLC2-50 but I've never really gotten it to work. Not in any of my A2000's or my A4000.
I had the CPU swap done by "hese" and at the same time he installed a voltage stepdown regulator 5V --> 3,3V, so the hardware should be top notch. Hese did say he got it working on his test rig but I've only once gotten the BIOS boot screen come up. 99% of the time I get the error 90 (coldboot) but I'll give this patched library a go when I have the time.
See when using it with your A4000 just be aware that the goldengate is fussy about the accelerator card used with it, well I know it is not compatible with the Cyberstorm MK1
Yes, I got the card working after the modification but can't recall if it was on A2000, A3000 or A4000. GoldenGate cards can be very frustrating to get running.Now this is interesting and possibly helpful! I also have a GG386 which is upgraded with a 486SXLC2-50 but I've never really gotten it to work. Not in any of my A2000's or my A4000.
