Installation of Catweasel MK4 drivers in Windows 7
oliver_guru
Spain
Caladan
Hi, amigos|
Anyone can tell me if the Catweasel MK4 installation under Windows 7 32 bits needs something else than just install the drivers? (I mean, properties>compatibility,etc...)
I am about to buy one and would like to know these things to go learning which steps I'll have to follow for when the card arrives :)
Thanks!
Only the drivers and the tools and that is all. You have to install the same drivers for all the Catweasel hardware one by one. I mean, the FDD controller, the joystick port, the SID chip, etc.
What I haven't managed to make it work is the Acid64 player. Windows had detected the 6581 SID but the applications says that not is detected. Anybody had this problem and solved it?
Amigo! Jajaja, los dos españoles y hablando en Ingles! :)
Siempre es agradable conocer a gente de la tierra que apoyo a nuestro Amiga!
¿Has podido instalar correctamente la Catweasel MK4 bajo Windows 7? ¿Has tenido alguna incompatibilidad o fallo grave de funcionamiento?
Gracias y encantado :)
Hola :) Todo perfecto pero solo en W7 32 como bien indicas ;)
Pongo la traducción a continuación porqué se tiene que escribir en inglés (normas del foro). Saludos desde Barcelona!
Translation (more or less):
All perfect but only on W7 32 as you pointed well.
By the way...about the Acid64 player I asked for help through the contact email and Wilfred, very fast and kindly, told me the solution:
"You should use an older version of ACID64 for getting support for Catweasel
cards.
The version you need is V2.40. You can get it here:
http://boswme.home.xs4all.nl/acid64/download/acid64_player_v240.zip"
