I must have been very tired last night, heres the link to the drive:
http://global.ebay.com/Teac_DV-28SL_Slot-Load_Slim-Line_Laufwerk/400061407822/item .
:tired:
Yeah, that drive is the same as mine with a bezel already mounted it seems. You could basically cut a BIG hole and fit the whole bezel in, or remove the bezel and mount it like I have except you have the button pre soldered. But the button you see on the drive may be fixed to the bezel, so when you remove the bezel, the button comes too. You'll still have a small button underneath, but it means you'd have to find something that can replace the bezel button and protrude outside the A1200 casing. Thats doable and you don't have to worry about soldering
