Sold New Amiga Buffred ide cd rom adapter Jp-Retro
  • Thread starter Thread starter ramparts
  • Replies Replies 46
  • Views Views 9283
Thank you Paulo for the correction I will test with 40 pin master slave cable an then post more info.
Best Regards
JOSÉ
no worries. Don't need CD-ROM.
What I need is a buffer for my CF-adapter :) .
And I can use a 44-to-40 IDE adapter.
Cheers,
McT
Hi Tested .
40 pin ide with 2 compact flash adapters one as master and other as slave and worked,although i require more test for cdrom also connected and i don´t have a pc psu at the moment to connect all the power .
But At least 2 cflash adapters worked on the same 40 pin line one as master and other as slave.
I will confirm more in the mean time as soon as i got a psu for test with floppy power cables :)
Best Regards
JOSÉ GONÇALVES
Abrief info on how to connect the adapter .
And with the compact flash adapter :)
Then you are set for installing software like idefix to detect the scsi unit.
With a longer ide cables you can install anywhere on amigathis is just an example
Best Regards
item arrived and works wonderfully.
Not in unit it was meant for but in an other.
The icons on the pcb are great. It is a great idea to point out the red wires!!
I'd say it is what the aide fix was meant to be.
Cheers,
McT
Thank you very much for your feedback
Hope to count with you in future product of us.
Best Regards
JOSÉ GONÇALVES
Units Available units.
Put dvd on your amiga or make your own amiga tower with dvd reader,lets your amiga 1200/600 play cd32 games ,audio files and more..
I am interested in purchasing a Buffered IDE interface, I live in the US.
How much
How much
Hi how much do these cost to ship to UK. Are they still available
