Just follow manuals and guides and therefore stay away from trouble..........
had a weird issue for a few days...seems to have gone though
i'm currently assembling some prelude/mpegit and get the same issue.I have the exact same problem since a couple of days ... suddenly hangs while playing and makes this weird sound. For no good reason.
All I can think off is reverting back to AmigaAmp 3.31 since it started occurinf after upgrading to the latest CafeineOS with 3.33
Is there any tooltypes to set...?Hi.
My Prelude / MPEGit setup / AHI 4.x si working fine appart from one thing.
Sound from OpenDune (automatically routed to AHI unit 0) is extremely faint, i thought it didn't work but i can hear voices if i push my Roland mixer to the max.
If i change AHI unit0 to an USB sounblaster device also connected to my setup, voices are ok.
I have the Mixer active in wbstartup with high level for every entry .
Any idea how to fix the level?
ahh i did that....turned everything up to the max superman mode lolActually i have fixed the problem which seems to be AHI related.
I use latest version 4.x. I used to push the channels slider to the max, from 1 to 32 because i thought it would be better. However, i have understood now that more channels means more softwares being able to use simultaneoulsy this AHI unit, which of course is not necessary, but then the more channels the lower the volume, so it seems.
I have encountered the same problem while playing MP3 to AHI Paula on my Vampire 1200 v2, and i ended using again my MAS Player to get loud 16 bits output even if it was not necessary to have a decoding hardware with that CPU. Again, it was fixed by returning to only 1 AHI channel.
I’ve been searching for this ‘dummy’ or ‘fake’ toccata.library file as well. All my searched seem to suggest it might exist, but I still have not found anything that works (to re-route to the prelude.library).I can try it...what i know is its a modded Tocatta.library that re-routes stuff to the prelude.library
Have you or anyone had any success in finding it or something similar?
Cheers,
Greg
