Hi , I may run another batch soon. Please be aware that I do not offer fully assembled units. This is DIY project. I may source for you additional parts like fans and 15pin connector but you will have to do wiring yourself or find someone who will do it for you.I have no clue what I should be asking for. I need a complete PSU and enclosure. Do you sell those? I have an Amiga 3000 - US model.
I can supply second hand PSU (FSP250-50GUF) as per description in sale thread. You will have to tell what TICK frequency you need (I suspect 60Hz once you ask about 110V PSU). Regarding conversion 110V to 220V I can not help you as I do not have enough knowledge.Yes that’s fine. Whatever you can supply is fine. I will have it assembled here in Belgium. If you can recommend the psu model unit to use that I can buy? Also I read something about a ticker which is also needed? One last question, can the 110v psu in my Amiga 3000 be converted to 220v? Like an internal switch or bridge wire?
Yes and the modification for 110V to 220V is very simple on A3000D: just ONE wire to desolder.Yes that’s fine. Whatever you can supply is fine. I will have it assembled here in Belgium. If you can recommend the psu model unit to use that I can buy? Also I read something about a ticker which is also needed? One last question, can the 110v psu in my Amiga 3000 be converted to 220v? Like an internal switch or bridge wire?
Items received in good condition. feedback leftDeclaring interest.
declaring interest (including the FSP-250-50GUF)
with the tick to be programmed for 50Hz please
Package received! That was fast. Thank you, @arymanx!Declaring interest.
Declaring interest for enclosure and Motherboard power connector.
(Marked as sold/completed by arymanx)
