For Sale PSU replacement enclosure for Amiga 3000D pre-order
  • Thread starter Thread starter arymanx
  • Replies Replies 126
  • Views Views 13962
I have no clue what I should be asking for. I need a complete PSU and enclosure. Do you sell those? I have an Amiga 3000 - US model.
Hi , I may run another batch soon. Please be aware that I do not offer fully assembled units. This is DIY project. I may source for you additional parts like fans and 15pin connector but you will have to do wiring yourself or find someone who will do it for you.
Yes that’s fine. Whatever you can supply is fine. I will have it assembled here in Belgium. If you can recommend the psu model unit to use that I can buy? Also I read something about a ticker which is also needed? One last question, can the 110v psu in my Amiga 3000 be converted to 220v? Like an internal switch or bridge wire?
I can supply second hand PSU (FSP250-50GUF) as per description in sale thread. You will have to tell what TICK frequency you need (I suspect 60Hz once you ask about 110V PSU). Regarding conversion 110V to 220V I can not help you as I do not have enough knowledge.
I am located in Belgium hence why I need to replace the psu to 220v. So for the ticker I guess I would need 50hz. Yea please to 2nd hand psu if you have one. Let me know when I can purchase. Thanks
Yes and the modification for 110V to 220V is very simple on A3000D: just ONE wire to desolder.
Please have a look here:
Thank you very much for the info. Even though I will of course do the procedure, I am still interested to acquire a new modern psu with a quieter fan etc.
declaring interest (including the FSP-250-50GUF)
with the tick to be programmed for 50Hz please
(Marked as sold/completed by arymanx)
Please program Tick module to 60hz.
*Update* Declaring interest in *two* enclosure kits,
both with a FSP-250-50GUF (if you have them) and
both Tick modules programmed to 60hz.
(Both are for USA model A3000D systems)
Thank You.
(Interest marked as expired by arymanx)
Kit including the FSP250-50GUF psu, 60 Hz Tick signal with shipment to US.
Declaring interest for enclosure and Motherboard power connector.
Oops!
Declaring interest for two enclosures, including fans and motherboard power connectors, both with the tick programmed for 50Hz and for one FSP-250-50GUF, please.
A complete setup
  1. RandomInexperiencedGuy
  2. anightin
  3. kavanoz
  4. nyteschayde
  5. sunmax
  6. Wrangler
  7. prosonic
  8. simon_m74
  9. RioBandit
  10. milo
  11. DocLeisure
  12. Robert_G
  13. StanMoonie
  14. utukku
  15. Dano
  16. tmoschella
  17. darkfather242
  18. RetroPanic
  19. samoht
  20. Davka
  21. trixster
  22. josephgut
  23. CodePoet
  24. Toaster4000
  25. RKolodziej
  26. alexscotti
  27. RobA1200
  28. josephgut
  29. dingebre
  30. Floppie209
  31. Sumselbrumsel
  32. akuehnemund
  33. nickrb
  34. Bruce72
  35. Titan.io
  36. MadMungo
  37. BITbyBIT
  38. wowjesstfc
  39. jeff_hanna
  40. michol
  41. Karl_Retro32
  42. dawgtool
  43. Bit-Image
  44. akuehnemund
  45. qz3fwd
  46. nekonoko
  47. Adi81
  48. Sir_Loin
  49. dawgtool
  50. DavidA3K
  51. AwakeningStar
  52. orwinjpo
  53. Hannibal
  54. ChrisHammond
  55. gewse2k
  56. wintersdtw
  57. Pixel /dev/null
  58. cyberstormer
  59. Jim_Oregon
  60. Mrpond
  61. jbrianc
  62. g.per
  63. sbrentson
