For Sale PSU replacement enclosure for Amiga 3000D pre-order
  • Thread starter Thread starter arymanx
  • Replies Replies 126
  • Views Views 13960
Declaring interest for 1 with FSP250-50GUFn and any other fancy fans or whatever will make it better
Tick to be 50Hz please
(Marked as sold/completed by arymanx)
Hello, I am attempting to do what you have already done here. I have several A3000s with stability issues. All were fine 10 years ago. No battery problems, they were replaced with coin type long ago. I am going to recap one of the PSUs and see if it helps. I also tried an ATX PSU (Solid Gear SDGR-FLEX-320) This unit is small and has the -5V line. I tried moving the MB jumper J350 for the tick signal, but that was not acceptable. I ordered parts to make a tick generator, but it seems you have solved that in a better way, also dealing with the -5V. I am definitely interested in this project.
Regards, John
Interested in 1 plus FSP250-50GUF
Declaring interest in a complete setup if available (with the FSP250-50GUF). Thanks
Should add: UK based so 50Hz Tick
I don't sell fully assembled PSUs. I have a few DIY kits still available. I build TICK boards to the order so it can take a few days before I will be able to post it. Please contact me via P.M.
Interested in 1 kit in including FSP250-50GUF and tick in 50hz
I did receive mine quite a while ago, just haven't found the time before today to start fiddling with it.
Enclosure quality is excellent, psu works.. just need to remove the 3.3v from the psu and plug the rest of the cables into the a3000 connector
I already received mine, thank you. Nice case.
There are no holes for the original A3000 PSU board.
I have an A3000 PSU internal, I wanted to install it, but I need to drill some holes in the side panel and base plate, etc.
Then I bought a Seasonic SSP-300sub, which has holes in the base plate, but the holes are unthreaded.
Question about the ATX PSU:
If I use the -12 (blue wire) for the tick generator module to generate -5, then the -12 wire for the Amiga3000 is missing.
How do I fix this?
Can I tap into the -12 wire for the tick module and the A3000 connector ?
How do I fix this?
When I asked if you require FSP250 50GUF you replied that no. I assumed that you sourced it yourself. If you could explain me your plans I would provide more details and for example tap additional holes ( you still can do it yourself if you have M3 tap).
I am sorry for misunderstanding.
In the first version of TICK PCB was only one soldering point for -12V. Wrangler mentioned in his video that it's problematic so I added another point. One can be used as IN another as OUT.
Please see picture.
Thank you very much.
I used these two images as a reference; a second -12V solder point is not visible.
However, the included modules have two -12V connections, as you can see in the image you posted.
I misunderstood. Please delete the old image that only shows one -12V connection.
The pinout diagram for the connector and the module is very helpful for laypeople like myself.
I would like one if possible. does power supply switch to 120v?
can you ship to states?
Thank you
Thank you :)
FSP250-50GUF is the power supply?
Yes. Do you need one? Or going to source yourself?
Thank you
Yes, power supply is full range (sold a few as part of the kit to USA). Yes I can ship to USA, but you may have to pay some custom duties now.
  1. RandomInexperiencedGuy
  2. anightin
  3. kavanoz
  4. nyteschayde
  5. sunmax
  6. Wrangler
  7. prosonic
  8. simon_m74
  9. RioBandit
  10. milo
  11. DocLeisure
  12. Robert_G
  13. StanMoonie
  14. utukku
  15. Dano
  16. tmoschella
  17. darkfather242
  18. RetroPanic
  19. samoht
  20. Davka
  21. trixster
  22. josephgut
  23. CodePoet
  24. Toaster4000
  25. RKolodziej
  26. alexscotti
  27. RobA1200
  28. josephgut
  29. dingebre
  30. Floppie209
  31. Sumselbrumsel
  32. akuehnemund
  33. nickrb
  34. Bruce72
  35. Titan.io
  36. MadMungo
  37. BITbyBIT
  38. wowjesstfc
  39. jeff_hanna
  40. michol
  41. Karl_Retro32
  42. dawgtool
  43. Bit-Image
  44. akuehnemund
  45. qz3fwd
  46. nekonoko
  47. Adi81
  48. Sir_Loin
  49. dawgtool
  50. DavidA3K
  51. AwakeningStar
  52. orwinjpo
  53. Hannibal
  54. ChrisHammond
  55. gewse2k
  56. wintersdtw
  57. Pixel /dev/null
  58. cyberstormer
  59. Jim_Oregon
  60. Mrpond
  61. jbrianc
  62. g.per
  63. sbrentson
