Repartitioning promo USB stick set to write protect?
Jumping Anaconda
Hertfordshire
I picked up a promo USB stick last week. When it is inserted into a Windows XP machine, it shows up as two partitions, I: and J:.
Partition I: is left empty for my use. The partition can be formatted but not deleted by XP's Disk Management tool.
Partition J: contains the promo, with 116 megs of photos. I can not delete any of the files on this partition, and any attempt to format it results in a message stating that the drive is write protected. The delete partition option is again greyed out in XP's Disk Management tool.
Is there likely to be any way I can delete these partitions and start from scratch? I am wondering if the drive might have been programmed at a firmware level to think that all the sectors on the J: partition have been used to their maximum number of cycles, making writing difficult. There are no obvious write tabs on the drive itself.
Looks like some custom partitioning. If possible you may want to plug it into a Linux system and try doing a:
"dd if=/dev/zero of=(path to drive) bs=1024 count=1"
Or in Windows run:
"diskpart"
"list disk"
"select disk (number of flash drive)"
"clean"
and in both cases you'll have to repartition and reformat, if it worked.
