Justin
right so i have a nice working A500 but it needs a little retrobrite love, anyone fancy suppling me a kit? and what about me not having any uv lights, will daylight be OK?
cheers, JuvUK
cheers, JuvUK
@ Juvster
I can send you some TAED and some Xanthan Gum, however, you'll need to source some H2O2 locally, from the local Sally's hairdressing supplies.
You want?
Daylight will be perfectly OK.
You don't get foaming at all with TAED as it's not a detergent, although gas generated by the reaction may cause it to "mousse up" a bit.
The Oxy products all have detergents added, so adding too much gets you foam icebergs all over the place.
The pound shop Oxy works just as well as the Vanish stuff.
I am currently running my first attempt (with Merlin's original recipe). Applied the mixture early evening and am thrilled to see how it all looks tomorrow morning.
One question: how thick do you apply the paste? Thinly spread or heavy duty?
Thanks!
Khondar
Yeah,
I think it's the wavelength of the UV that's the issue. We need 320nm UV light and most black lights are weak at this wavelength, unless you pay an arm and a leg.
Good results though!!
