Say hello to the brand new Amiga A500 accelerator card - the TF530 (Terrible Fire 530
  • Thread starter Thread starter 8 Bit Dreams
  • Replies Replies 295
  • Views Views 83093
Interested in a board for an Amiga 2000. I have a GVP SCSI controller in there (not sure of model # at moment) with (I think) either 4MB or 6MB of memory. Would the 2 boards live happily together do you think?
have seen reports that it works, however, i can not test, as i do not own GVP, sorry
Hi, the TF will work in the A2000 with the vampire adapter to put it in the CPU slot, however, it doesn't work with other memory boards and the like I have found. ie: by itself it works just fine.
this will be fixed soon - Stephen found a bug in the FW that causes these issues
@DjCook
Got your PM, sorry for late reply, I was down with flu, sick as a dog and shivering like a nutter :-(
Money ready
Still avaliable? If avaliable, then I declare interest, pending a couple of questions....
My questions is regarding this card, running in an late model 500 (rev 8a.1 non-plus machine)
- Can I close the case, with this accelerator card?
- I have an ScanPlusECS in my Amiga500. Will it fit with my scandoubler, or do I need a special CPU relocator?
- Is a CPU cooler recommended? If so, what are the dimensions, that I need to look for?
- What type of the following storage options, can I use with this accelerator: IDE, CF, SD?
- Can I use one of them dual kickstart switchers that have 1.3 and 3.1 in one?
- Can it run with the 2mb trapdoor mem upgrade from boobip? I have the one with gary adaptor and all that.
- How compatible is the 030 compared to 000, when playing the old games?
Thanks in advance.
Yes, still available
Yes, but 68k socket relocator is needed (it is included in my set, so no problems with fitting)
Never seen this before, can U explain please why is it needed? I am using an RGB to HDMI upscaler and run my Amiga on 50" LED TV in High Definition
passive cooler is included in my set, You can also add a small 5vdc fan if You wish
IDE Hard drives, DOMs (Disk On Module), CF Cards, SD Cards (with CF to SD adapter)
sure, You can, but 1.3 need to be patched with scsi.device driver if You like to boot using it as in original 1.3 kickstart doesn't have this driver
Your questions are about rev 8a.1, it is better to mod trapdoor expansion to get 2MB chipRAM, You will be able to run almost all WHDLoad games then
some games will not boot from Floppy, but who cares, since You can boot from ide - You will use WHDLoad instread of floppies, and WHDLoad needs at least 010 cpu for "Quit" function, 030 is even better
The reason why I am using an ScanPlusECS, is that I need to use a modern flatscreen lcd monitor. I have this setup running, as I get headache from most CRT's and my woman gets migrane from CRT's. So I am using a scandoubler that takes up the same amount of space, as the IndevisionECS does.
Thanks for the replies on the other questions that I had. Sounds really great. Thanks.
I do understand what You mean, i dont like CRT's for same reason, that's why i was looking for a good solution. I have a big range of retro computers, so i have choosed this:
https://www.ebay.de/itm/Scart-HDMI-...EU-Stecker-10-10-2-5-mm-Upscaler/232901162089
and i must admit i am very happy with it. This can also be a good solution for US and some other Amiga users, who doesn't have SCART TV's in their country, as it converts and upscales Amiga RGB output to Full HD
- - - - Update - - - -
Payment received from Brostenen
for 1x TF530 Set for A500
Ahhh... Those I know about. They have been praised a lot. :-) Though I went for the internal scandoubler solution instead. I like internal stuff, in order to get as clean a table, as possible. The problem with the ScanPlusECS, is that it is running at 50hz refresh rate only. As to why I had to hunt down a special LCD monitor that can sync to that refresh rate. CRT monitors have no issues there. Though both of my IBM monitors and my Samsung can not do it.
Anyway...
I have sent 156,5 Euro through paypal. Regarding the CPU relocator. If you can ship it with one that moves the board up, instead of the angled one, then I think it can fit with the scandoubler that I have. It raises the Denise up, into the same height as an Gary adaptor does. I have seen that the Denise are clear from the board, when using the one that only shift the accelerator up. So if they are just as compatible as the angled one, then I think it will work.
Payment received from Brostenen for 1xTF530 A500 Set. Will update tracking info once parcel is sent..
1xTF530 A500 Set for Brostenen was sent
Parcel to pnasman was delivered - positive feedback exchanged
Thanks for the update. Looking forward to install it and get HDD storage working on it. :-P
I was thinking, if the board will allow me to mod my 8a.1 board from 500 to 500-Plus.
I am thinking about getting 1mb Chip onboard, and then add additional 1mb chip from trapdoor.
have done it with three boards till now, works excellent, the biggest issue for me was to source 74F139 and RAM chips
