Vampire 600 V2 - Amiga 600 FPGA accelerator Pre-order
  • Thread starter Thread starter majsta
  • Replies Replies 1459
  • Views Views 402947
With 128mb on board, there is no ram shortage! I plan on getting a USB controller on my 604n I am hoping that will be supported still.
This is what i hope too. I allready got ecs indivision ECS and subway usb controller. At least i hope the controller will work. Vampire should not atleast interfere with the left 1200 clock port. But you never know.
With different drivers both clockport on A600 works. clockports placed in 2 different mem areas. So you got 2 chances it could work. :)
Other than the 604n and rtc my 600 is recapped, modulator removed stock. So I have no clockport drivers installed. Once the vampire arrives I hope to get USB and is 3.9 bought and installed (I already own an original 3.9 CD as I use it under emulation on my MorphOS Mac mini.)
I brought a 4gb cf flash card for hdd and an indi ECS for the A600 a while back... now it looks like the Vampire can handle all these things (Hope they get the HDMI bit implemented quick). I don't have a TV for the A600, just a monitor.
bugger that's all I can say.
Nice :)
Not too long ago i recaped my mobo. And removed modulator for hdmi :)
I hope that the 10 cm long hdmi IN with both hdmi and dvi out will fit where RF was. :)
Aos3.9 i owned for decades. Has also custom my original kick 3.1. To 3.1/3.9 switch. Needed for cheap sata adapter to boot my ssd.
Woah! No Indivision ECS support? That is a severe handicap. WB and games look gorgeus with the Indivision. Even if the Vampire has RTG, games videomodes won't be scandoubled. Is not there any way to change the conflicting addressing? I would gladly sacrifice Fast Mem if that allows the Indivision to work.
Enviado desde mi iPhone utilizando Tapatalk
I don't, on board HDMI will hopefully make the indivision redundant anyway!
And I am sure they will look better still on 720p or 1080p, whatever the HDMI out can handle.
But as far as I understand, for the time being the HDMI output will only be used for the RTG.
I am sure full HDMI support will come.
For a full HDMI support you'd have to implement ECS in the core. I guess they might implement some form of Super-AGA that would be backwards compatible to a degree but I don't think it's a priority.
