CraigsBar
Yep. These are being soldered and shipped by majsta alone (I believe kipper2k is soldering for his orders) so anything more than 2 a week is good going. I am not holding my breath, but this year would be nice.
That has more to do with the dimension and stiffness of the cable and less than of the connector being used. I found a thin and rather flexible HDMI cable which I think should be suitable. I guess I'll find out when I receive my board. Also, the cable could be tied to something in the correct position to relieve any stress from the Vampire board.i think mini hdmi or micro hdmi might of fitted better on vampire 2 has people reporting when connect cable pops the vampire off the cpu has tight fit.
Which one does the Vampire have? Micro or mini? I would like to buy before hand. Any links to the best hdmi cable (from people who already have their boards) would be great.
Cheers
Ah good find, I was looking for something like this. Compact, slim, short and M2F.Which one does the Vampire have? Micro or mini? I would like to buy before hand. Any links to the best hdmi cable (from people who already have their boards) would be great.
Cheers
I have my Vamp and have tried a few cables but need a male to female so I can put the female end on a board and put it where the rf module was ,this is ordered now
http://www.ebay.co.uk/itm/111913220816?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Male side on that one looks too bulky if you still have floppy drive. (It also looks a bit stiff.)On my side I will try to build something with this extension:
https://www.ebay.com.au/ulk/itm/201237722776
Maybe will use the extension door with a 3D printed model...
But 3d printed backplate has crossed my mind too. But maybe there's a bit less space there than you remember.
Check this pic
http://www.exretro.com/galleries/co...re/index.html#eX_Vampire600v2_RF_vs_HDMI1.jpg
The wide female mount with screws in your link would come very close to the PSU connector.
I thought the same thing, but they are very big. If you have the floppy drive installed there is no room.Is there room for something like these angled adapters? If they fit it could let you use a cable that normally might tend to pop the Vampire off.
http://www.amazon.com/gp/aw/d/B00EKTN01S/qid=1458939359
I don't have my V2 as of yet, but I just got an HDMI cable which I think will be suitable. The connectors are small and the cable is thin and flexible:
http://www.biltema.dk/da/Kontor---Teknik/TV-audio-og-video/Kabler/HDMI/HDMI-kabel-2000035256/
I then intend on putting a gender changer in the RF modulator location, hoping I can secure it there somehow:
http://www.biltema.dk/da/Kontor---Teknik/TV-audio-og-video/Kabler/HDMI/HDMI---HDMI-2000033445/
The cable is probably fine, but I think you wanna fix it to the case somewhere so that you don't pull the Vampire card directly if you happen to pull the cable on the "Amiga end".
