Closed VIC20 VC20 Plug'n'play S-Video Modification
  • Thread starter Thread starter mrr19121970
  • Replies Replies 171
  • Views Views 37505
mrr19121970
Germany
Hessen
CURRENTLY NOT BEING OFFERED
Know the problem? VIC20 colours don't line up? Red, Cyan, Green, Yellow & Purple text can't really be read? Black, white and blue seem to be ok?
Here is the answer...
Chroma/Luma mod. Plug and play. No soldering needed (your 6560/6561 VIC-I chip needs to be socketed). Remove the lid of the RF shield ('tin'). Lift the chip out (taking ESD precautions, noting the orientation of the chip). Pop in my mod, the wire on the socket will go over the top of the top of the 'tin' and between the 'fingers' of the lid. The cable is traced around the back of the 'tin' and between the serial and video outputs, secured to the motherboard (eyelet next to datasette edge connector). Replace the 6560/6561 VIC-I chip. Simply plug in the supplied cable into the back of the VIC20 and connect the 2x 1pin DuPont connectors and the RCA connectors to your monitor and bam. Crisp clean colours like you've never seen before.
The Problem
The chroma 'creeps' on brighter colours. visble gaps between pixels on blue and almost checkerboard on red/cyan/purple/green/yellow:
The Mod
Plug, play. No soldering skills needed. Screwdriver to open the case and assist lifting the VIC-I chip only. Total fitting time, less than it took me to type this offer...
The Results
Rich deep colours, no checkerboard pattern. Like seeing the beach for the 1st time in your life.
The Price
20 euros including worldwide postage (as a letter upto 500g). Other postage (tracked, insured, registered at cost if needed)
Price increases 1 euro per metre for cables for longer (21€->2m, 22€->3m, 23€->4m and 24€->5m)
Payment
Family'n'Friends PayPal only.
The Package
A) CURRENTLY NOT BEING OFFERED >>> S-Video MOD (soldered to modified 40 pin socket)
B) CURRENTLY NOT BEING OFFERED >>> 3 RCA connector, 1.4m cable with custom fiting (5 PIN DIN & 1 pin DuPont) for 1701/1702/1084 Monitor
or
B) CURRENTLY NOT BEING OFFERED >>>4 RCA connector, 1.4m cable with custom fiting (5 PIN DIN & 1 pin DuPont) for 1084S Monitor
or
B) CURRENTLY NOT BEING OFFERED >>> S-Video/audio cable (1 meter long) with custom fitting (5 pin DIN and 1 pin DuPont)
Custom made by me for you (small lead time), and tested on my VIC20 before posting.
Orders
Please register interest here, and send me a PM with your required cable length.
Boray REFERENCE SITE
Chicgamer REFERENCE SITE
Update
If needed then a cable for 1701/1702/1084 monitor can be supplied instead. Please specify this. Length 1.4m. Price 21 euros
also 1084s monitor cable (1.4m Price 21 euros)
Please make sure you use ESD precautions (touch a radiator/heizung) and then open the case. Keep touching the radiator from time to time. Prize the 6561-101 VIC-I chip (note the original direction) out with a small flat head screwdriver. Carefully insert the mod into the socket (PIN2 is missing, and a red wire is attached). This should be the same direction as the VIC-I was (PIN1 is top right as you face the mainboard). When the mod is inserted, replace the VIC-I chip and guide the cable with the 'dupont' connector (attach to the mainboard next to the datasette edge connector with a cable tie). Reassemble VIC20.
Now connect VIDEO and DuPont to DuPont. Connect to TV. Power up VIC20, power up TV. Hopefully there is a remarkable difference.
See here for a step by step guide. Thanks to Sven.
Received my cable today - video quality on my VIC has never looked better! Had a slight issue with the wire coming loose from the IC socket, but easily fixed with 2 minutes of soldering though. Very happy with results, thanks!
Thanks for the feedback. I am now using foam to protect the socket legs and the mod wire on the socket too
@warkopz your second mod + cable was posted already
@amigo-mexicano Sorry for the delay (I'm bad). Well I don't have an NTSC model that can benefit from the MOD. Yes it will work, but there is no point in fixing if not broken?
