68060 on ACA500 Amiga 500
  • Replies Replies 110
  • Views Views 27140
@Mike
Have you tried booting the 060 under 3.1 without RAM (I have a suspicion ;))
Jens said no 32bit card will work on 16bit A500 properly. Fast 030 is a max.
Hi Keith
same result, yellow screen and instant reboot - cycle
Could try turning some of the option(s) on/off in the blizzard card menu on a A1200 then re-test on A500.
Worlds first??? surely this needs a separate photo booth moment...
Not really, sorry :) I ran my Blizzard1260 on the ACA more than a month ago, but not being able to use kickstart 3.1 is a problem.
BTW: running a BlizzardPPC won't work, so running AmigaOS4.1 in the Amiga 500 is a no go for now... (that would have been a first!)
---------- Post added at 09:40 ---------- Previous post was at 09:40 ----------
Mmmmmm....BlizzardPPC / 060 / BlizzardVision anyone? :)
Doesn't work, sorry :(
For now :) Until EVERYTHING has been tried (initial thoughts of custom firmware, various settings, modified kickstarts, hacks etc) I don't think that "it doesn't work" is a result to accept :p This IS Amiga, and there is some VERY talented people in the scene...so let's just see...
I have one on the way also, when it's here I will do some tests.
The thing is, if you have an ACA 1220 or 1232 on their, it's more than enough.
Let's face it, what is the point of having 060 or PPC in any Amiga ?
OS4.1 and few PPC games and demo's is the only thing, with the new Cyrus coming, I think that would be a better choice if you really want to get into that.
And for demos, most 060 demos are AGA, so you'll lack the most important thing.
Zeus68k will be a lot better if it really has AGA.
Very interesting, I never thought that an 68060 can run on a A500 but dreams come true sometimes ;) thank you jens that you made the ACA500!
from jens on 1K.org
.. and the statement brings us to a really simple solution, which is unfortunately not occurred to me: you can turn off the CPU in "transparent translation registers" of both data and instruction caches as well as the 060 CPU. The TTR eke the Amiga a nearly unnoticed existence, because they always relate to a 16 MB block.
For the ACA500 but this is ideal because the * entire * lower 16MB block (just the entire A500) is from the perspective of the 68060 non-cacheable, ergo it does not hurt to disable the caches on the way depend on your location. Fastmem is outside, so grab because the caches again, and the B1260 * might * work. Subjunctive, because a matching 68040 library is missing, also retains this setting.
Groundwork for this is already done, coming in the next version of Flash.
Jens
http://www.a1k.org/forum/showthread.php?t=41442&page=3
Here is a beta version for Blizzard owners . The 68040/68060-Karten work, but the library must not be used under any circumstances , otherwise again , the caches are turned on in the lower 16M , and that pops immediately.
You can display the processor to the CPU command , normally turn the caches (which are active only on the local Fastmem the B1260 ), but the Blizzard SCSI module will NOT work , because running out of DMA controller of a fully functioning MMU - and is not there without a 68060.library replacement.
In the ACA500 menu a little more info text is now added to come - but with F10 in the expert menu , or use the TAB key call up the info screen : It is now also checked whether the $ f8 - range over which the ACA500 usually their Residents fades , is covered by the 1200 Turbo card (" shadowed "). In that case , this means that the function of Maprom Blizzard is active, and menu options can not be changed until the next power cycle . We have not yet succeeded in a " Maprom " which is turned on in the Blizzard once off again (hints welcome).
Other changes:
- ICache is now turned on the ROM Unzip , so the unpacking with 32- bit Turbo card is noticeably faster
- If B1260 is found, the unpack routine is placed in the Fastmem this card , which makes the unpacking process rapidly
- Maprom function of ACA12xx card is automatically used so that ACAtune is not needed (which anyway does not work with the ACA500 )
- $ C0 memory is automatically switched on at ACA1230 , so that Execbase is in any case as soon as possible Fastmem - again, no more need for ACAtune
This is an interim release . Tests should be done only if you have created a rescue disk. It might have crept in new errors that make it necessary to go back to an older version back !
The resident- command " acamaprom " also gets another update, so the Maprom function of the Blizzard can be activated ( ie you can load kickstart files) .
thanks Mike.
me too , just done it. Does the Blizzard 060 libs work?
---------- Post added at 17:46 ---------- Previous post was at 17:44 ----------
Flash update: files on next post
flash pics and file.
Copy unzipped file to your CF card and run the flash up date tool from the advanced menu.
( create a flash recovery disk first)
  • menu500.aca.zip
    menu500.aca.zip
Okay
So the new firmware allows booting into 3.1 Workbench but it then reboots as though the 060 libs are wrong or something else is.. if i boot with no startup sequence then i can get into workbench but obviously SYSinfo crashes the system ...
on a clean CF WB install , it loads up okay and runs very quick. however sys info or sys speed still crashes it.
mike
Great progress, so a new 68060 library would do the trick. That's almost an excuse to buy another 1260 :D
How does the Maprom work if you want to load your own custom Rom?
at the moment any Blizzard tool crashes the system. anything that seems not too taxing is working okay.
a vanilla 3.1 install is the only to get my one working , so no WHDload or demos at the mo...
i'll continue playing
thanks Mike.
No, sadly we need a reworked 060lib for the combination ACA500/1260. :(
damn ... you any good at coding?
Also the SCSI doesn't crash the ACA500 now but I'm getting the wrong ram allocation..
mike.
i think that should 96mb ...but i could have the wrong ximm in (i did , ram allocation working great)
It runs fine as long as you don't run any programs that touch MMU or TTRs (transparent translation registers) or it will immediately hang the system because they restore original and incompatible cache settings for lowest 16M of address space. Also FPU is disabled and can't be used.
68040/060 library update or patch is needed that keeps lowest 16M totally uncacheable (for both data and instruction caches).
btw, "C:CPU cache" can be used to enable data caches (noticeable speed increase) but it will break SCSI expansion because it is DMA and DMA controllers require proper MMU tables with 68040 or 68060 CPUs.
thanks Toni i will try as I'm still more or less sober
