JHanna
Yes. Thought I said that in previous posts.
Boom there it is
Well at least you know what the problem is.
They are eeproms so you could get them reflashed, will say the are marked as just A4K ROMs and not A4KT ROMs.
The drive termination is required with the SCSI device: A4000T SCSI Controller -- Drive -- Drive -- Termination
What fixed 3.2.2? Did you get the new roms?
You know hdtoolbox only scans the one device it it told to scan, right? (In its icon tooltypes) Is it set to scan the scsi?
What are your SCSI dip switches set to? Default is off (down) for all of them.
Bfg works just fine with the scsi on my 4000T.
(I don’t think it’s a dma bus master)
BDB: You did what, and why? (Dip #7 set to OFF enables scsi termination on the motherboard and disables external SCSI)
On the A4000T both the IDE and SCSI use the same scsi.device. All the dip switches should be left in the default. screwing with them is never neededWhat fixed 3.2.2? Did you get the new roms?
If the 50-pin cable terminates in a 50-pin terminator, all (8) data lines are terminated (this means that the data lines are prevented from "ringing " or signal degredation). For a 68-pin cable, a matching 68-pin terminator is used.Would improper termination cause the drive not to get recognised at all? The built in terminator won't terminate the upper 8 bits of the SCSI bus. Ordering some adapters with high byte termination to see if that makes the drive play nice with the A4000T.
