Hi there, my adaptors arrived in Australia today. 17 days of travel.
Hooked them up to my partially built Amiga 1200 and connected to a Dell 2001FP and after some tweaking, the images is PRISTINE. Still only got a Kickstart screen as my CF card is currently being built but I am very happy with the results so far.
Will provide a further update when she's up and running properly.
Also, anyone else on here using a Dell 2001FP? It seems when I adjust pixel clock and phase to get the correct image it doesn't remember the details. Do I have to keep doing these each time I turn the monitor on?
Cheers,
Steve
@ a.mi.goun
How about testing DblPAL High Res No Flicker screenmode?
I'm very curious, because then I don't need an expensive flickerfixer
anymore. :roll:
@ a.mi.goun
anymore. :roll:
I have a benq BL702A and i tried DblPal but the workbench doesn´t fill the screen (black vertical borders),
also i have some small vertical bands...What is your screen resolution, pixel clock and phase ?
regards
CBM
@ a.mi.goun
anymore. :roll:
regards
CBM
The borders appear in PAL, NTSC, DblPAL & DblNTSC. I've solved it with the Overscan Prefs.
My screen resolution is PAL: 716 x 564. Pixelclock 90, Phase: 21.
regards
CBM
Thanks for your tips. I changed to DBLNTSC with pixel clock, and phase 21, and noticed improvement.
When you said that your reslution is PAL, are you talking about PAL HIGH RES monitor driver ? The workbench fills the monitor screen completly ?
