| View attachment 2440049 | Amiga Video RGB to VGA Adapter
- Allows connecting Amiga native Video to LCD monitor with just a VGA cable. If that monitor supports 15 kHz mode (like BenQ BL702A or BL912), you will get a great picture comparable to a scandoubler. More info here. For deluxe adapters and more options check here. | Price:
11 € |
| View attachment 2440050 | Amiga Video RGB to VGA Cable
- An alternative to Amiga Video RGB - VGA Adapter is completly modified SVGA cable for even more comfortable and easiest way of connecting Amiga to BenQ BL702A / BL912 or any other 15kHz compatible monitor. (Please note that for bigbox Amigas such as A4000 and monitors other then BenQ BL702A / BL912 you need buffered sync signal). Buffered sync is for extra 5 €. For deluxe cables and more options check here. | Price:
15 € |
| Amiga Video RGB to GBS 8200 (8220 or HD-VC9900) Cable
- This cable will connect your Amiga to GBS 8200 Video Converter. Also compatible with GBS 8220 and HD-VC9900. High quality shielded videocable. You can choose either round cable (to connect to VGA in) or a flat type cable (to connect to P11 connector). Comes with 680 Ohm resistor on CSync as recommended. | Price:
14 € |
| View attachment 2440051 | SCART-VGA (CSync) Cable Adapter
- This cable adapter can be used to connect your Amiga (and other retro computers/consoles) to GBS-8200 (and similar) video converter or BenQ BL702A or BL912 monitors assuming you already have SCART cable (wired for CSync) for your computer/console. Optionaly I can also add an audio output (in case your computer/console only outputs audio thru scart). | Price:
14 € |
| Minimig / MiST / MiSTer SCART Cable
- Allows connecting Minimig, MiST and MiSTer to TV/LCD with the SCART input. SVGA grade videocable with ferite filters for perfect picture. | 14 € |
| Minimig / MiST Video Cable for Commodore 1084S Monitor
- Allows connecting Minimig or MiST to Commodore 1084S D-Sub 9pin Video Input. Cable will work with Philips CM 8833-II monitor too. | Price:
10 € |
| Commodore 1084(S) and Philips CM8833-II RGB-Video Cable
- Amiga RGB-Video Cable for Commodore 1084(S) monitor and Philips CM8833-II. Options are: 1/ Commodore 1084S-D1 (or Commodore 2002 or Phillips CM8833-II) monitor with DSUB(Canon) connector (photo). 2/ Commodore 1084S-P1 monitor with DIN connector (photo). | Price:
15 € |
| View attachment 2440052 | Amiga SCART cable
- Gives great picture on TV / LCDs with SCART connector. For deluxe SCART cables follow thread here. | 15 € |
| View attachment 2440053 | Amiga CD32 RGB SCART cable
- RGB SCART cable for Amiga CD32. CD32 must have the 8pin MiniDIN connector, that provides RGB signals. Only the French CD32 had that connector, others have 4pin MiniDIN (where only SVideo signals are present). | 17 € |
| View attachment 2440054 | Ratte Auto Switch Video Cables
- Cables for Ratte Auto Switch. Options are: 1/ Indivision internal cable to Ratte Switch INPUT1(A) (5 €), 2/ Cable from Amiga external VGA scandoubler to Ratte INPUT1(A) (11 €), 3/ Cable from Amiga external RGB Video to Ratte 10pin port (for use with 15kHz compatible monitor) (12 €) (photo), 4/ Cable from Graphics card VGA output to Ratte INPUT2(B) (11 €) | Price:
11 € |
| DataSwitch Amiga Solution
- Allows multiple Amigas on one table share one Keyboard, Mouse, Joystick, Audio with the help of a manual DataSwitch. More info here in my other thread. | |
| View attachment 2440055 | ADF-Copy Adapter Photo1, Photo2, Photo3
- Comfortable solution for writing and reading Amiga floppy disks from PC with USB port by Dominik Tonn based on advanced Arduino compatible controller. Among its unique features is the ADFDrive that allows working with the floppy disk as it was an USB thumbdrive. Also HD floppy disks support and recently added flux-level support for reading disks into SCP format. Nice java-based GUI with lots of useful features. And compatible with various Operatining systems, not only Windows. Price for the adatper is 43 €, optionaly Micro USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 5 €. When you like it consider donating to the Dominik thru his website! | 43 € |
| Arduino Amiga Floppy Disk Reader/Writer
- Another solution for writing and reading Amiga floppy disks from PC with USB port by Robert Smith. Can read and write ADF files to(from) disk with easy to use program from Windows. Newly supports reading to SCP files and also direct floppy disk support with WinUAE emulator. Price for the adatper is 27 €, optionaly Mini USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 5 €. | 27 € |
| View attachment 2440056 | Greaseweazle F1 (Bluepill) FDD Reader/Writer
- Great USB converter by keirf for writing and reading (not only) Amiga floppy disks from PC. Working on a flux level, it can read & write SCP, HFE and ADF file formats and also write IPF files. That means it can even duplicate originals. When you like to converter consider donation to keirf! Price for the adapter is 21 €, optionaly Micro USB cable 1,5€, USB power cable for floppy drive 5 €. | 21 € |
| View attachment 2440057 | ADTWin Cable
- Allows writing Amiga disks from PC with Parallel port (for more info check ADTWin website). Built according to the most recent scheme. Optionaly USB power Cable to power the Floppy drive for 6 € or PC floppy drive for 8 €. | Price:
10,5 € |
| View attachment 2440058 | Cable for connecting GOTEK as external floppy drive
- With this cable you can connect GOTEK floppy as external floppy drive. Gotek is powered directly from external port just like any regular external floppy drive. Cable features genuine 23pin dsub connector. Many cable colors available to choose from in my original thread here. | 16 € |
| View attachment 2440059 | A500/500+/1000/2000/3000 Bootselector
- For A500, A500+, A1000, A2000, A3000 users I can offer a boot-selector, that allows booting from the external Gotek (or external floppy drive). The adapter connects to CIA (B) slot. You just remove the CIA chip, place it in the adapter socket and put the adapter in place. With the switch you can select if internal or external drive is bootable. When external drive is bootable, internal drive becomes invisible. Simply - you can have either DF0 (internal) + DF1 (external) or just DF0 (external). On bigbox Amigas drives just swap being all visible and accessible. | 17 € |
| View attachment 2440060 | Amiga - SEGA MegaDrive Pad Adapter
- Allows safe and correct function of MegaDrive pads on Amiga and C64 (swapped 5V /Select lines + resistor and all signals connected thru diodes). Please note this will not make a full-feature replacement to CD32 joypad, megadrive pad will work only as a standard joypad with 1-2 button support. Short version of the adapter (photo) fits directly also to Amiga 600 & C64. | 10 € |
| SEGA MasterSystem LightGun/Phaser 3050 - Amiga Adapter
- Allows connecting SEGA MasterSystem LightGun/Phaser 3050 or compatible to Amiga to play supported WHDLoad modified games with it. | 10,5 € |
| View attachment 2440061 | Amiga - IOMEGA Zip100 Parallel Port Drive Adapter
- Allows connecting parallel port ZIP drive to Amiga (uses Amiga Parallel and Joystick port). For use in big-box Amigas ask me for making longer joystick cable. New improved version now includes fully shielded cover and passthru joystick connector that can be made to fit A600 as well. Special version for Amiga 1000 could be made on request. | 16,5 € |
| View attachment 2440062 | SDBOX - Parallel Port Micro SD card Reader/Writer
- Allows connecting MicroSD cards to Amiga parallel port for filetransfers. And with a suitable driver boot disk you can make your sdcard work as a portable harrdisk for every amiga (kick 1.3 and higher). For powering SDBox external usb charger is needed or you can power it directly from Amiga with my Floppy port USB power cable.
Version 1 is for 31€ or Version 2 (which supports insert/removal of cards on the fly) is 35€ | 31 € |
| Amiga 1000 Standard Parallel port Adapter
- This adapter converts non-standard parallel port built in Amiga 1000 into standard Amiga type parallel port. | 12 € |
| View attachment 2440063 | Amiga CD32 Standard Serial Port
- This adapter cable connects to AUX in CD32 and converts it into standard 9-pin serial port (like the Communicator device does). On CD32 only RX, TX signals are present, but it still allows file transfers or playing multiplayer serial games. | 13 € |
| ParNET cable
- Allows connecting 2 Amigas for transfering data and quite fast (files can be accesed thru NET: device in system, just like any other drive/device) | 12 € |
| Serial Nullmodem cable
- Allows connecting 2 Amigas for playing supported multiplayer games or for transfering data. Can come as 3wire or 7wire (for faster transfer rate). Cable can be also made with small COM connector for connecting Amiga to PC. 3wire cable price 9 €, 7wire 11 €. | 9 € |
| Easy 1541 Cable
- Allows connecting Commodore 1541 (and compatible) drive to Amiga to transfer files etc. | 10 € |
| Frodo IEC Cable
- Allows connecting Commodore 1541 (and compatible) drive to Amiga and use it by Frodo C64 Emulator to to transfer files or run the C64 software directly from the drive. | 14 € |
| View attachment 2440064 | Amiga-PS2 Mouse Cable Adapter
- Allows connecting standard PC PS2 mouse to Amiga. Adapter can come with either PS2 or USB connector (Mouse still has to support PS2 protocol). All adapter types are listed here. | 18,5 € |
| Amiga-USB Mouse (and Gamepad) Cable Adapter *NEW
- Allows connecting standard USB type mouse to Amiga. Even some wireless mice works. Adapter can also connect some USB Gamepads as standard joysticks. | 20 € |
| View attachment 2440065 | A600 mouse/joystick port adapter
- This adapter allows connecting devices to Amiga 600 mouse/joystick that normally would not fit because they use larger connector. Cable version also available. | 4,5 € |
| Joystick UP & Fire Swap adapter
- With this adapter you can swap your joystick's 'UP' direction & 'FIRE' button, so that you can press fire button for jump and the fire is routed to second fire-button (if present). Useful in jumpy games like James Pond 2 Robocod, where most people prefer FIRE button for Jump. Only way is to swap the signal lines and that is what the adapter does. You can decide whether you want swap: UP to Fire1, or UP to Fire2. You can also decide if you want original 'UP' connected or disconnected. Default mapping is UP to Fire1, Fire2 to Fire, original UP disconnected. Connector is compatible with A600 and C64 too. | 6 € |
| View attachment 2440066 | Amiga "low-space" mouse/joystick port cable extender & adapter
- This special 9pin Dsub (canon) cable extender allows connecting devices mice/joysticks to Amigas where there is very little space near ports that prevents fitting normal connectors. Also useful in towerized amigas to extend the connectors. Connector will even fit to A600 mouse port, so this cable can be also used as A600 mouse port adapter. You can decide length of the cable. | 5 € |
| Parallel port laplink cable
- This parallel port cable allows easy filetransfers between Amiga and PC through direct Parallel port connection. PC Drives are mounted on Amiga as Devices which allows easy file management. You need an old PC otherwise timeouts may occur. Long filenames are supported thanks MSDOS 7 or FreeDOS and DOSLFN. Kickstart 2.0+ is needed to run PC2Am. Software in action is presented here. | 10 € |
| Paradise Amiga-PC Parallel port cable
- This parallel port cable allows fast filetransfers between Amiga and PC through Paradise software. The latest version of the software adds direct usage from Windows. | 11 € |
| View attachment 2440067 | PS2 Keyboard - Amiga Mini Cable Adapter
- Allows connecting PS2 Keyboards to bigbox Amigas such as A1000/A2000/3000/4000 or CD32 and CDTV. Follow my original thread here for more info. | 17,5 € |
| CDTV Keyboard to CD32 (and A4000) or A2000/3000 Adapter
- This adapter allows connecting CDTV Keyboard to either Amiga CD32 (and A4000) or A2000/3000. | 11,5 € |
| Blizzard vision / Cybervision PPC VGA Cable
- Internal VGA Cable for Blizzardvision (BPPC) or Cybervision (CVPPC) graphics cards. You can decide the length of the cable (default 35cm). | 10 € |
| Indivision ECS or AGA MK1 internal Scandoubler/Flickerfixer cable
- Cable which connects internal Indivision ECS (or Indivision AGA MK1) to Monitor. You can decide the length of the cable. | 10 € |
| Indivision AGA MK2cr (or MK3) internal Scandoubler/Flickerfixer VGA cable
- Cable for Indivision AGA MK2cr with VGA connector. Default length is 30cm. Price is 11,5 € for MK2cr cable and 13 € for MK3 cable. | 11,5 € |
| Indivision AGA MK2cr internal Scandoubler/Flickerfixer HDMI cable
- Cable for Indivision AGA MK2cr with HDMI connector. The HDMI connector can be installed in place of removed RF modulator (you can either screw or glue it in place) or mount on a bracket etc. Cable's HDMI female coupler can be detached to small HDMI plug. Default length 30cm.
Cable2 with small HDMI socket available as well. | 23 € |
| Indivision AGA MK3 internal Scandoubler/Flickerfixer HDMI cable
- Cable for Indivision AGA MK3 with HDMI connector. The HDMI connector can either be installed in place of removed RF modulator (you can either screw or glue it in place) or mounted on a bracket etc. Cable's HDMI female coupler can be detached to small HDMI plug. Default length 30cm.Cable2 with small HDMI socket available as well. | 23 € |
| Indivision AGA MK2cr internal Scandoubler/Flickerfixer DVI cable
- Cable for Indivision AGA MK2cr with DVI connector (female) providing both analog and digital signal just like the original cable. Can be used as a replacement for a broken original cable. Default cable length is 30 cm. Can be made longer or shorter if needed.
Optionaly I can supply with smaller and low profile DVI connector (photo) for +1 €. | 17 € |
| DCE internal Scandoubler/Flickerfixer cable
- Cable which connects internal DCE Scandoubler/Flickerfixer to Monitor. | 10 € |
| Amiga 4-Player Adapter
- This adapter allows connecting 2 more joysticks to Amiga to parallel port for playing multiplayer games such as Dynablaster and many others (list of supported games for example here). Also on PC you can use the adapter with PPjoy driver (for windows XP and older) to use amiga joysticks as digital joysticks. Adapter is wired to support also the second button. | 10 € |
| Amiga Floppy DF0 Terminator
- This adapter removes the delay when floppy drive is not connected to internal floppy drive port. | 3,5 € |
| Amiga 4000 IDE Terminator
- This adapter removes long delay when you reset Amiga and you do not use any IDE Devices. Useful when booting from other controller such as Fast ATA/SCSI etc. | 3,5 € |
| Blizzard SCSI-Kit IV internal cable
- Internal SCSI cable for Blizzard SCSI Kit IV. Allows connecting one scsi 50pin device, default length 35cm. Custom length or more connectors on request. | 12 € |
| Blizzard SCSI-Kit IV original cable
- Original SCSI cable for Blizzard SCSI Kit IV with the external DB25 female connector. Can be made with male DB25 connector as well if requested. | 10 € |
| Squirrel SCSI ext-int cable
- With this cable you can connect internal SCSI devices such HDD's to Squirrel PCMCIA SCSI controller. | 9 € |
| IDE 2,5->3,5 Adapter
- With this adapter you can connect 3,5" IDE cables into internal A1200/A600 IDE connector. Power cable provides +5V power if needed. | 5 € |
| DIN - PS2 Adapter
- Adapter allows to connect old DIN keyboard to PS2 connector. For example A2000 and A3000 keyboard to A4000. | 2,5 € |
| PS2 - DIN Adapter
- Adapter allows to connect PS2 keyboard to DIN connector. For example A4000 keyboard to A2000 or A3000. | 5 € |
| Floppy power cable
- Used to power floppy drives on A500/600/1200 etc. On request I can make other custom power cables, for example cable with three small plugs to power also CF adapters etc. | 6 € |
| Amiga M1438 Microvitec RGB monitor - VGA adapter
- Allows connecting Amiga (Microvitec) multisync monitors (that come with 23pin RGB cable) to VGA port (15pin) such as graphics card on Amiga or PC. Features genuine 23pin connector. | 14 € |
| Amiga - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 500/500+/600/1200. As there is no supply of original square DIN connector, I use my modified round connector, that work well. Comes with ON-OFF switch. | 17 € |
| Amiga 1200 Micronik Busboard - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 1200 equipped with Micronik Bus Expansion Board | 18 € |
| Amiga 2000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 2000 and thus replace the old, noisy and failing original PSU. | 17 € |
| Amiga 3000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 3000 and thus replace the old, noisy and failing original PSU. | 17 € |
| Amiga 3000T - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 3000T and thus replace the old, noisy and failing original PSU. | 21 € |
| Amiga 4000 - ATX Power Supply Adapter
- With this adapter you can connect standard PC ATX Power supply to Amiga 4000 and thus replace the old, noisy and failing original PSU. Especialy well suited for desktop A4000 thanks to perfect power distribution. | 17 € |
| Amiga CD32 - ATX Power Supply Adapter
- With this adapter you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) from a standard PC ATX power supply. | 14 € |
| Amiga CD32 - Molex Power Supply Adapter
- With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with a standard molex connector of the AT/ATX power supply. | 9 € |
| Amiga CD32 - Cisco Power Supply Adapter Cable
- With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with CISCO ADP-29EB power supply. | 13 € |
| Floppy Port - USB Power Cable
- This cable can be used to power low-power devices such as SDBox or Plipbox directly from Amiga external Floppy Drive Port. USB connector can be miniUSB or microUSB at your wish. Default length is 20cm. Can come with modified DB25 connector for 11 € or genuine 23pin connector for 13,5 €. | 11 € |
| Amiga-PC Serial Nullmodem Adapter
- With this adapter you can make serial connection between Amiga-PC (and viceversa) for example to transfer data with Amiga explorer or other similar software. Wired for full handshaking (required by Amiga Explorer). If your PC does not have serial (COM) port you can use USB-RS232 Converter (I can supply one for 4 €). | 9 € |
| Amiga 4000 IDE Splitter cable
- This cable enables you use both CF-Card Adapter and CDROM on A4000 internal IDE controller. You may have noticed that when directly connecting CF-Adapter and CDROM to A4000 the CDROM is not recognized. This special cable works similar way as 4xIDE splitters (I integrated the capability directly into the cable), and enables another channel for the CDROM thus making it available. With the help of IDEFix software you can then access the CDROM thru atapi.device on unit 3. | 11 € |
| Paravision SX-1 external HDD cable
- With this cable you can connect standard 40pin IDE device to external HDD connector of the Paravision SX-1 expansion for CD32. As the port provides also +5V, the cable offers posibility to power devices that are ok with just +5V (ideal for CF card adapters). | 18 € |
| 68030 or 68040 / 68060 Heatsink (standard or low-profile)
- Hi-quality anodized aluminium heatsink for 68060 or 68040 CPU (Dimesions L:45,7mm, W:45,7mm, H:16,5mm) for 7€ (photo). Also available Low-Profile version (photo) (Dimensions: L:42,5mm, W:45mm, H:6mm) for 4 €. Also available low-profile heatsink for 68030 CPU (Dimesions L:35mm, W:35mm, H:6mm) for 3,5 € (photo). Heatsinks are highly efficient. I can also include hi-quality adhesive tape for the heatsink for additional 1 €. | |
| Crystal Oscillator 70 Mhz
- Useful when you want to experiment with overclocking your Blizzard / Cyberstorm Accelerator. Take care of proper processor cooling when operating overclocked. | 3 € |
| TF 328 PCB
- Terrible Fire 328 accelerator for CD32 - just PCB -not populated. Bought from S.J Leary years ago. Only one PCB for sale. | 12 € |
| Amiga Test Kit Parallel and Serial Dognles
- Set of Parallel and Serial Dongles for easy testing these Amiga ports with famous Amiga Test Kit program. | 18 € |
| AMIGA MIDI Interface *NEW
- The MIDI interface for serial port provides Amiga with MIDI Out and MIDI In port for connection of the MIDI hardware. Compatible with the popular MT32-Pi project.
Also available MIDI Out interface for Amiga CD32 which connects to AUX port and gives one buffered MIDI out port for 16,50 €. | 24 € |
