Will PM just after but I need a special pair of real DB23 cables for my 1200 Tower to use with my Graffiti video card.
My Graffiti card is mounted INSIDE the tower, but connected to a PCI bracket.
Internally, I want a cable permanently connected between the OUTPUT of the Graffiti and a Male DB23 connector on a second PCI bracket above the Grafitti.
Externally, I want a loose cable, permanently connected to the INPUT of the Graffiti and a Female DB23 connector that I would connect to the motherboard video output when I want to use the Graffiti.
So:
First cable will be external and needs DB23 housings to look good. Specification is Male on one side, Female on the other. This cable should be round and about 30 cm long
Second cable will be internal and doesn't need DB23 housing as one side will be connected to the Graffiti and the other side will be surface mounted internally to a PCI bracket.
