Zeph
As IDE cables are straight through, as long as you reverse the pins on both ends you could put it the other way around anyway if you needed too, as I said, as long as it's reversed on both ends of the cable
If you are not specifically tied to a cf card, then my solution was to use a 44 pin ide DOM directly onto the socket. It stands up from the board to about 2cm. Everything else fits fine with it.A second option is to buy a 20cm ide cable. And let the cable go between vampire and motherboard. Im awaiting 20cm cable from aliexpressi try this first on aca620. Until vamp 600 arrives
I have tried to do the "other way around" with cable it works with cf card. But i got Sata adapter and ssd.
Third option is to buy a cf adapter with angeled female 44 pin connector and attach adapter to mobo without the ide cable. Im not 100% sure it would fit though
Edit:i mean fit between motherboard and vampire.
I can see if it fits since a got an female adapter @ home.
I too hope it is.Any word if it is compatable with the A604A / Rapid Road USB controller?
It was possible to get one Vampire? If yes... i want to buy it.
Pedro
"Kipper2k's website is where you order now" ....
i ask to the email on Kipper2k's website but he does not answer ....
is it possible to order a vampire II here ?
He will answer... eventually. If you'll take look on the homepage you'll find out that Kipper2k opened preorders December 21st and by January 23th he fullfilled all preorders up to... drumroll... December 23rd."Kipper2k's website is where you order now" ....
Once kickstart3.1 uploaded (1 week ago for me), should we let someone special know about it or is the process engaged ? So far I still see my kickstart in the root directory of the server...
You beat me too it.... JustOn the first post if you click on the link it will take you to a post from Kipper
>>>Kickstart 3.1 upload info<<<
