Hi guys,
some of you asked about IDE extension and how it can be done since flat ribbon cable is very short on TF534...
Well, short cable is here for stability reasons, TF5xx card ide isn't buffered, if ide ribbon will be long - this will lead to read/write issues..
this leads to situation where case need to be opened each tome You want to remove or swap CF card.. Not nice at all...
To fix these issues we need two hardware parts:
instread of CF to IDE we use SD to IDE:
And to extend our IDE we take SD card extender, it is buffered and it works without issues to me..
These both parts may be found on ebay, for cheap, i paid about 6€ for SD to IDE and 1,5€ for SD extender..
Beside of that, some or You noticed that after installing muFASTROM (MMULibs)
http://aminet.net/package/util/libs/MMULib.lha
instread of IDE speed increase there was a slowdown, so it actually worked opposite..Well this is something what i can't explain atm, Sysinfo shows slow speed however ide works fast.. all i can tell -some CF Cards interfere with CF Adapter and this happens. Using SD to IDE adapter solves this strange issue and Sysinfo reports much higher IDE speed..
Please let me know about your experience..
With kind regards,
-Viktor
