For Sale Useful Amiga Cables & Adapters
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 1576
  • Views Views 227766
I have a question about this item:
Cable for connecting GOTEK as external floppy drive
- With this cable you can connect GOTEK floppy as external drive. Gotek is powered directly from external port and shows in system as DF1:. Cable features genuine 23pin dsub connector. Many cable colors available to choose from in my original thread here.
You wrote that Gotek is shown as DF1, but the board of gotek must be set up as ds1 o ds0? With a boot selector it should be set as ds0 since DF0 is deactivated and gotek should be seen as DF0.
I wanted understand if it is possible with this cable.
Thnaks :)
Thanks for a good question. In fact, the cable works as follows: when S0 set on Gotek it appears as DF1. When S1 set on Gotek it appears as DF2.
When Amiga has two internal drives, it shows as DF2 or DF3 depending on S-jumper on Gotek.
So with a boot selector it will always appear as DF1 (with gotek set as ds0) also when I want to deactivate internal drive with a boot-selector and use the gotek as DF0? :unsure:
Can you describe your setup more detailed?
Generaly with a bootselector (on A500), you can make the external Gotek bootable (which then shows as DF0:) and then your internal real drive becomes invisible.
Actually my gotek is put inside an external drive case, connected to the mobo of this unit (which has a power supply in order to activate and deactivate it). I have also a boot selector which works well with DF0 selected but does not work when DF1 is selected to work as DF0.
I set up gotek both as ds1 and ds0 but does not work when put as DF0 with boot selector, while works fine as DF1 when set up as ds1.
I noticed, also with another external disk drive, that it must receive signal from DF0 before start to work as DF1; this depends from the board of external unit I suppose.
So if I connect the gotek directly to Amiga as DF1 with your cable it should work and boot as DF0 with boot-selector, since there's no the passthrow from external drive board.
But now I have new doubts since you wrote that with your cable when S0 set on Gotek it appears as DF1. When S1 set on Gotek it appears as DF2.
So can it work as DF0 with a boot-selector?
Ok, I'll take one :)
What is difference between the one you sell here at 15 euro and the others in the dedicated thread?
You can pick the cable you prefer in the dedicated thread (link is on the first post). There is different colors to choose from.
I would like to buy 2 x Amiga "low-space" mouse/joystick port cable extender & adapter.
Interested in a heat sink for TF360 so low profile I think with adhesive.
Hi. Interested in the Amiga*CD32*-*Cisco*Power Supply Adapter, with shipment to the UK.
  1. TRONiC
  2. omar
  3. helgebl
  4. vHDLer
  5. gounderset
  6. Dale423
  7. Xanxi
  8. Cathal
  9. Overmann
  10. Akiko80
  11. pedgaard
  12. Timtheloon
  13. QMadx64
  14. nMAC
  15. neuron55
  16. CCRider
  17. Benzo
  18. paolopal
  19. bdb
  20. neuron55
  21. TommoLB
  22. jaiyenjohn
  23. Peckmore
  24. beej199
  25. dframeli
  26. Jameson
  27. steveed
  28. tramal
  29. DarrenHD
  30. Cbergeman
  31. jkdsteve
  32. G-linx
  33. plaw123
  34. jurassicman
  35. RobertB
  36. Toaster4000
  37. qz3fwd
  38. Overdoc
  39. LordAga
  40. IgorK
  41. Jameson
  42. Dale423
  43. suppah
  44. marchigianluca
  45. Unimatrix
  46. neocdtv
  47. Dege
  48. costner460
  49. captainmoomoo
  50. alama
  51. tommytamsen
  52. hese
  53. CyanPixie
  54. SantiDarkG
  55. Rontti
  56. Rakeim132
  57. kavanoz
  58. cgugl
  59. VoltureX
  60. MrClump
  61. Adam.
  62. Christacean
  63. MrClump
  64. Qix
  65. Stormi
  66. samplist
  67. cv643d
  68. cloverskull
  69. TheNey
  70. gewse2k
  71. DocLeisure
  72. softinn
  73. tramal
  74. chrisgreen
  75. DoctorQ
  76. captainmoomoo
  77. jargo
  78. chrisgreen
  79. costner460
  80. gdaniels215
  81. jrendean
  82. kalkkuna
  83. Disturbed
  84. NorthWay
  85. solipsyta
  86. Akiko80
  87. nickrb
  88. jargo
  89. witchdoctor75
  90. Timtheloon
  91. MaLuKa
  92. Wirerob
  93. DocLeisure
  94. Darby_Crash
  95. Blopztar
  96. bn1029
  97. Raef
  98. Rakeim132
  99. samoht
  100. Nori
  101. amigat
  102. Br0ther
  103. Boing-ball
  104. bedrock
  105. xavlahaye
  106. cyberms
  107. stratos
  108. Darby_Crash
  109. Ariadne24
  110. salaxi54
  111. samoht
  112. Predseda
  113. Ariadne24
  114. Dale423
  115. Boing-ball
  116. jos1970
  117. rhys
  118. Sven1977
  119. utukku
  120. Jameson
  121. cloverskull
  122. XTelefonator
  123. weekendroady
  124. cv643d
  125. vinman
  126. pipper
  127. ferrumm
  128. RandomInexperiencedGuy
  129. bomberoza
  130. Amiga Forever
  131. theq1337
  132. DocLeisure
  133. AwakeningStar
  134. costner460
  135. DiLf
  136. Nek3d
  137. ProfPlum
  138. Haybags4000
  139. St233t
  140. hms
  141. bpa
  142. Oldman1000
  143. lguglielmo
  144. Vasilii
  145. realBruce
  146. PGOAT
  147. jbrianc
  148. Nightshft
  149. HomeLate
  150. mariovieira
  151. Xanxi
  152. VoltureX
  153. tobitt
  154. retrotechtive
  155. utri007
  156. Overmann
  157. Mrsmile
  158. xavlahaye
