For Sale Useful Amiga Cables & Adapters
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 1576
  • Views Views 227777
Interested in 2x A600 mouse/joystick cable extension. Would love them to be 10cm long maxi... and white as the picture.
Thanks
Added A600 mouse/joystick port cable adapter to the list of the offered adapters.
- This special home-made 9pin Dsub (canon) cable extender allows connecting devices to Amiga 600 mouse/joystick that normally would not fit. You can connect all my adapters to A600 thanks to this modified cable. The connection is 1:1, all 9 signal lines connected, so you can use this adapter cable with other computers/consoles as well if needed.
... this one.
Hi A.mi.goun
Do you have a cable for doing this : Having a DF0-DF1 boot selector, for connect a gotek and a real floppy drive in internal of an a500 ?
I want to integrate my gotek and my real floppy on my a500 :) A boot with df0 or df1 :)
May be i must change
Thanks
Ok, i found your thread.
I need an internal cable for DF0 floppy and DF1 gotek (no external).
And a switch to change DF0 to DF1 ans DF1 to DF0 :)
Do you have one ?
Great.
From what I know, it is impossible to have two floppy drives on internal cable on A500 without additional logic, that is present in bigbox amigas. But not quite sure about floppy and gotek, I remember I saw a thread here someone having something like that, but if only I am able to find it again :)
Did some tests. And interestingly it works :) At least on my A600. DF0-1 switching would possibly require routing some signal from external port.
Added 1438 RGB monitor - VGA adapter.
Allows connecting Amiga (Microvitec) multisync monitors (with 23pin RGB cable) to VGA port (15pin) such as graphics card on Amiga or PC.
Added Amiga 2000 - ATX Power Supply Adapter.
With this adapter you can connect standard PC ATX Power supply to Amiga 2000 and thus replace the old, noisy and failing original PSU.
Joystick UP & Fire Swap adapter from my other thread added to the list of offered adapters.
- With this small adapter you can connect your joystick and it will swap the 'UP' & 'FIRE' buttons, so that you can press fire button for jump and the fire is routed to second fire button. Many people me including like to press fire for jump in jumpy games like James Pond 2 Robocod any many more games but these games are coded for only UP direction for Jump. Only way is to swap the signal lines and that is what the adapter does. You can decide whether you want swap: UP for Fire1, or UP for Fire2. The other Fire button will be mapped for fire. You need 2 fire button joystick to have both fire and up. You can also decide if you want UP button disconnected or connected both 'UP' and 'second fire button' for jump.
  1. TRONiC
  2. omar
  3. helgebl
  4. vHDLer
  5. gounderset
  6. Dale423
  7. Xanxi
  8. Cathal
  9. Overmann
  10. Akiko80
  11. pedgaard
  12. Timtheloon
  13. QMadx64
  14. nMAC
  15. neuron55
  16. CCRider
  17. Benzo
  18. paolopal
  19. bdb
  20. neuron55
  21. TommoLB
  22. jaiyenjohn
  23. Peckmore
  24. beej199
  25. dframeli
  26. Jameson
  27. steveed
  28. tramal
  29. DarrenHD
  30. Cbergeman
  31. jkdsteve
  32. G-linx
  33. plaw123
  34. jurassicman
  35. RobertB
  36. Toaster4000
  37. qz3fwd
  38. Overdoc
  39. LordAga
  40. IgorK
  41. Jameson
  42. Dale423
  43. suppah
  44. marchigianluca
  45. Unimatrix
  46. neocdtv
  47. Dege
  48. costner460
  49. captainmoomoo
  50. alama
  51. tommytamsen
  52. hese
  53. CyanPixie
  54. SantiDarkG
  55. Rontti
  56. Rakeim132
  57. kavanoz
  58. cgugl
  59. VoltureX
  60. MrClump
  61. Adam.
  62. Christacean
  63. MrClump
  64. Qix
  65. Stormi
  66. samplist
  67. cv643d
  68. cloverskull
  69. TheNey
  70. gewse2k
  71. DocLeisure
  72. softinn
  73. tramal
  74. chrisgreen
  75. DoctorQ
  76. captainmoomoo
  77. jargo
  78. chrisgreen
  79. costner460
  80. gdaniels215
  81. jrendean
  82. kalkkuna
  83. Disturbed
  84. NorthWay
  85. solipsyta
  86. Akiko80
  87. nickrb
  88. jargo
  89. witchdoctor75
  90. Timtheloon
  91. MaLuKa
  92. Wirerob
  93. DocLeisure
  94. Darby_Crash
  95. Blopztar
  96. bn1029
  97. Raef
  98. Rakeim132
  99. samoht
  100. Nori
  101. amigat
  102. Br0ther
  103. Boing-ball
  104. bedrock
  105. xavlahaye
  106. cyberms
  107. stratos
  108. Darby_Crash
  109. Ariadne24
  110. salaxi54
  111. samoht
  112. Predseda
  113. Ariadne24
  114. Dale423
  115. Boing-ball
  116. jos1970
  117. rhys
  118. Sven1977
  119. utukku
  120. Jameson
  121. cloverskull
  122. XTelefonator
  123. weekendroady
  124. cv643d
  125. vinman
  126. pipper
  127. ferrumm
  128. RandomInexperiencedGuy
  129. bomberoza
  130. Amiga Forever
  131. theq1337
  132. DocLeisure
  133. AwakeningStar
  134. costner460
  135. DiLf
  136. Nek3d
  137. ProfPlum
  138. Haybags4000
  139. St233t
  140. hms
  141. bpa
  142. Oldman1000
  143. lguglielmo
  144. Vasilii
  145. realBruce
  146. PGOAT
  147. jbrianc
  148. Nightshft
  149. HomeLate
  150. mariovieira
  151. Xanxi
  152. VoltureX
  153. tobitt
  154. retrotechtive
  155. utri007
  156. Overmann
  157. Mrsmile
  158. xavlahaye
