Vampire 600 V2 - Amiga 600 FPGA accelerator Pre-order
  • Thread starter Thread starter majsta
  • Replies Replies 1459
  • Views Views 402955
Great job with this a600 v2
I'm still waiting :)
This is great stuff.
But i must have 2 posts to able to reply message :(
Its not cool.
So.. those of you that have your v2... how are you hooking up/routing the HDMI cable with the case on?
Sent from my SAMSUNG-SM-G890A using Tapatalk
In a perfect world, someone would make a 3d printed bracket to hold a HDMI port and 2 usb ports (driven by a rapidroad or something) and have it fit where the RF modulator is.
Hi Im going to use hdmi extension with flat cable http://www.ebay.co.uk/itm/111427887369?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT not sure how I will mount it in rf modulator place might try cable ties for now
Think it's reasonable to assume that pretty much everyone will realize that the RF modulator is of little use. However... not everyone will want to alter the original case, I guess...
Personally, I'll remove the RF modulator and likely mount some kind of 3d printed bracket with HDMI connector.
Skickat från min HTC One via Tapatalk
[However... not everyone will want to alter the original case, I guess...
Rf-modulator hole is big enough to fit vga without changing a case. So it should fit hdmi easily.
Maybe I chose my words poorly. I know it fits. I mentioned a 3d printed backplate to hold a connector. So room for plastic around the connector :-)
What I meant was that there are ppl (purists / collectors etc) who don't wanna alter the original look of their Amigas by permanently removing a part from the motherboard which can also be seen from the outside.
Yep, exactly. I'm fairly sure you could fit HDMI + two vertically placed USB ports in the space. I've never done anything 3d printing related, but this might just motivate me to... once I finally get my board, that is. :)
Is it easy to remove the rf modulator? I'm not as handy with a soldering iron as I'd like to be.
can anyone here suggest the best and cheapest hdmi cable for the vampire. ive heard that bigger cables can pop the card off?
